8th Gen 2006 - 2011.
does 2007 civic coup left axle has a abs ring?
Old 10-09-2012
smilecow's Avatar
smilecow is an unknown quantity at this point
hello
i am a newbie.
I am going to replace my left cv shaft but I don't know whether I need to buy cv shaft with a abs ring or not.
After I change, I will definitely post a how-to article with pics. thank you
smilecow is offline
Old 10-09-2012
Re: does 2007 civic coup left axle has a abs ring?
First obvious questions:
Does the car have ABS?
Does a yellow ABS light light up on the dash for 2 seconds with all the other lights when you turn the key on?
Does the axle currently have an ABS ring on it?
If the car has ABS on it, you definitely need the ABS ring on the axle.
(Even if the car doesn't, an axle with the ring will still fit so you can be safe either way.)
And why are you replacing an axle on an 07 already? I haven't seen a bad one yet here. No boots opened up from weather cracking at all.
ezone is offline
Old 10-09-2012
smilecow's Avatar
the boot is still ok but I hear the clicking noise from the left. I checked every bushing around the left axle but can't figure out where it is coming. I am going to replace the cv shaft first because that noise is like the shaft shot. I hope it is the right one.
smilecow is offline
Poopies
04-20-2017 11:36 PM
miatabro
07-17-2015 12:12 PM
shaejb15
04-26-2015 07:44 PM
15EXCoupe
04-19-2015 09:26 PM
CapYoda
11-11-2001 05:17 PM
Quick Reply: does 2007 civic coup left axle has a abs ring?
