8th Gen 2006 - 2011.
2012 Honda Civic EX 'Engine Braking' with Econ Button?
Old 08-06-2012
guitaressamc's Avatar
guitaressamc is an unknown quantity at this point
I recently purchased a NEW 2012 Honda Civic EX. I love it! I'm just worried that there may be something wrong with the engine or transmission. With the Econ button on when I test drove it, it seemed like it was using engine braking like a large truck does when you let off of the gas pedal rapidly (the RPMs soar to down shift and slow the car down). I also noticed that after braking for a prolonged period of time at a high speed going down a large hill that it seemed to be doing this 'engine braking' thing again. The RPMs soared as it down shifted to decrease my speed. Is this considered normal? Has any one else noticed this??
Last edited by sdaidoji; 11-16-2013 at 05:13 PM. Reason: Moved - not a DIY, informative, but still a question
guitaressamc is offline
Old 08-06-2012
JustinOhio's Avatar
JustinOhio is an unknown quantity at this point
Re: 2012 Honda Civic EX 'Engine Braking' with Econ Button?
I have noticed this too! I have a new 2012 EX Coupe and I get this phenomena happening. I use ECON mode all the time though unless I'm going to be passing a few cars. I notice the engine breaking also when going downhill and braking a little at the same time. Strange.
JustinOhio is offline
Old 08-06-2012
CraigW's Avatar
G R A D E __ L O G I C
Don't care for it much myself, YOU will adjust... but not the car. Takes a while.
Also watch for the slowing down, then needing acceleration and it bucks/jerks and acts all crazy.
CraigW is offline
Old 08-10-2012
New Civic Owner
jsquaredmn's Avatar
jsquaredmn is an unknown quantity at this point
i have a new LX coupe as well and commute 170 miles a day and have never noticed this...i have my econ on 95% of the time...i would say that is not normal and you should have it checked out while it is still under warranty
jsquaredmn is offline
Old 08-11-2012
does it downshift without pressing on the brake when going downhill? if so that is very strange behavior for any car. if it only happens when pressing the brakes downhill, its part of the trans grade logic control. really stupid, but no way to disable.
gearbox is offline
Old 08-21-2012
jkunsman's Avatar
jkunsman is an unknown quantity at this point
I have a 2012 LX and it does it all the time. If I am going down a large hill that is going to go back up and I just want to be able to control it myself I will bump into neutral to aviod the grade control. Sucks but what r ya gonna do!
jkunsman is offline
Old 10-25-2012
0396's Avatar
0396 is an unknown quantity at this point
My 2012 HF does all of the above mentioned. I believe it's normal- so far so good with trans. Oh I did changed the tranny fluid at 20k...and when it drained, it smelled semi brunt already.
0396 is offline
jessicakaybby
04-20-2015 12:11 PM
civic_gt
04-19-2015 08:15 AM
ashleymmackey
04-18-2015 09:48 PM
chgofirefighter
04-18-2015 08:08 PM
Quick Reply: 2012 Honda Civic EX 'Engine Braking' with Econ Button?
