Replacing drive belt 2010 civic
Old 09-15-2015
stank's Avatar
stank is an unknown quantity at this point
How do you change the ribbed drive belt on a 2010 civic 1.8 L engine with AC. It is supposed to have a hydraulic belt tensioner. Neither the guy at the local Autozone nor I can figure which pulley or nut is the correct one to place a wrench on to loosen. The nut we are using is 19 mm but it will not move and we don't want to over do it . Could someone post a video on loosening and removing and installing this belt. I bought a manual at the auto parts store but it is of very little use, basically says "loosen the belt". Thanks
Old 09-15-2015
Re: Replacing drive belt 2010 civic
The 19mm hex is correct.
Use a long box end wrench.
Apply hard, slow, steady hand pressure toward the firewall.
The hydraulic tensioner is one strong SOB and it takes a long time to compress it.
Applying excessive force can cause breakage!
Those factory belts are made of EPDM rubber and will last a damn long time, turning brown is not a good reason to replace it (they all seem to turn brown), but cracking is a good reason IMO.
Most last well beyond 100k miles here.
Aftermarket belts tend to not last near as long as OEM.
HTH
Old 09-16-2015
CraigW's Avatar
I have read you want to move tensioner slowly when replacing. (mechanic) did mine at 100k.
Xuhme
21
08-07-2023 03:40 PM
Linda0818
04-23-2015 11:30 AM
MamaBear2015
26
04-16-2015 11:08 PM
smmahan
04-15-2015 08:17 PM
aus10
04-13-2015 09:26 PM
Quick Reply: Replacing drive belt 2010 civic
