How Much?
Old Jun 16, 2003
Elite's Avatar
Elite is an unknown quantity at this point
Angry How Much?
Ok well I was changing the oil and of corse I didn't put safety stops by the tires and after I had finished lifting the car with a jack front end, which I know is really stupid but my friend told me that i messed up the cord support for the front end and radiator the metal bars that hold the radiator I got a job and I really want to fix that nasty hood its like a half and inch open and my radiator hoses are sliced and I can see green stuff all over my engine anyways plz don't flame thanks I am just wondering how much it will cost to fix it as you can see the pix in my ride you will notice the hood just up a little bit thanks. This really irritates the hell out of me. Do you know how much an estimate on replacing the front end of the frame thats the only part thats damaged, its bent like an upside down V right under the radiator basically.
Check my Members Ride pics and you'll see thanks.
Old Jun 16, 2003
Elite's Avatar
Oh btw I got my car repainted because of vandals in my neighbor hood, god.. I hate haters... it pisses me off now i park inside my garage. I will post some pics of my current ride tomorrow.
Old Jun 17, 2003
gotti's Avatar
Please, if you re-do your first post with correct punctuation, I'll try to help you. I read halfway through it and it made my head hurt.
Old Jun 17, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
I can say this... if you've got antifreeze leaking, don't turn the car on. You'll overheat it if you drive to far. Now if I understand this right... you bent the frame crossmember under the car? How the **** did you do that? I've jacked my car up from there tons of times and it doesn't do anything. or did you bend the lower radiator mount? Damn, I think that's welded in, you'll have to find a bodyshop that has a frame puller or something to bend it straight... and even then it won't be perfect. As far as the radiator hoses go, get some new ones and re-fill the radiator with coolant.
Old Jun 27, 2003
Elite's Avatar
my car doesnt over heat or anything, basically the bottom metal under the radiator is bent like an upside down v its not that bad but I need an estimate, its a little cut in the hose
