Backfiring?
Old Jun 5, 2003
CivicRacer5's Avatar
CivicRacer5 is an unknown quantity at this point
Backfiring?
When i am in 3rd or 4th gear at like 2,000 rpms, and i quickly floor it, i have noticed that my exhaust pops like a backfire. I have 2.25 inch custom exhaust with a universal muffler, would that cause it to backfire because of loss of back pressure or is something else wrong? PLEASE HELP!
Old Jun 5, 2003
Red2k3Civic's Avatar
Red2k3Civic is an unknown quantity at this point
mine happens every once in a while, its weird, but it happens some.
Old Jun 6, 2003
R3DL1N3's Avatar
backfirings cool, does fire come out your exhaust
Old Jun 7, 2003
david02civic's Avatar
I'm The Shit
david02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusted
mine does the exact same thing and i have the same exaust set up as you, 2.25 custom cat back with tanabe muffler.
Old Jun 9, 2003
Cat's Avatar
Cat
My fiancee's car backfires, too. He's got an exhaust, but even before he had that it would still backfire. I always laugh when it happens. It's pretty funny.
Old Jun 9, 2003
R3DL1N3's Avatar
i think its cool myself. DONT HATE ON THE BACKFIRE. i wish mine did it with FIRE! FIRE! AHHH!
Old Jun 9, 2003
Mbow's Avatar
The ecu is probably still adjusting to the new exhaust. I think it is dumping too much fuel. It happened to my accord several years ago. It went away after a few weeks.
Old Jun 9, 2003
Cat's Avatar
Cat
I love the backfire because it's just so random. You never know when to expect it and since it catches us off guard, it makes it even more funny.
Old Jun 12, 2003
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
No way, the backfiring on my car sounds pretty cool, it's not too loud at all and it only does it when i'm going slow. It does it pretty randomly too...
Old Jul 4, 2003
CapYoda's Avatar
Escaped Convict
oh my god not to restart old threads but...
backfiring isn't good for the engine, and it shouldn't be like that.
you lose horsepower due to unspent gas going back into the exhaust manifold,
or at least, thats what it seems like in this scenario, since the problem occured when you swap your exhaust system...
there's a leak somewhere... or the system wasn't put together correctly, *shrug*
but if its a problem such as gasket leak, or burnt gasket... it will eventually do some harm in some area... (ie: burn away the manifold block if its the gasket between the header and the manifold, and eventually damaging the aluminum block...)
Old Jul 4, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
so retorque all your exhaust / header bolts...... and check gaskets?
Old Jul 5, 2003
KeNsHiN's Avatar
LEVA
universal muffler= problem
Old Jul 6, 2003
Mbow's Avatar
Like I said, it is usually the ecu adjusting and simply dumping too much fuel due to the increase airflow. It should go away on it's own. If not, you need to do further investigation if it continues longer than a month or two.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
SimpleUser
Apr 24, 2021 02:54 AM
Valkman
Aug 13, 2015 04:19 PM
trev0006
Feb 26, 2005 03:46 AM
DarkCivic
Oct 5, 2002 04:32 PM
