Installing JIC-Magic FLT-A2 tonight have questions...(update INSTALLED)
Old May 28, 2003
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
Will the RSX kit fit without modification? Obviously no one on this forum has them installed but does anyone know of anybody that does?
thanks
Old May 28, 2003
robbclark1's Avatar
Retired suspension supermod.
I think it will need modification. Hondawerx says that you need control arms from a RSX, but other than that I don't know.
Old May 28, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
You need RSX tie rod ends. I think the stock tie rod might need to be shaved a little, but I cannot say how much.
Front axles if you're doing the brake conversion but that won't work unless you have the K-series engine with it because where's the intermediate driveshaft going to go for a D17 engine?
Old May 28, 2003
Your Parts Guy
actually I just found out from Zeil Motorsports that the EP ones will fit and thats what we are installing. for anyone interested, the EP FLT-A2 are out.
Old May 28, 2003
Nitek's Avatar
Nitek is an unknown quantity at this point
i believe the rear lower shock mount may have to be shaved fit the shock in (correct me if im wrong). other than that, it should be straight up forward. Just wondering where did you get the jic flt-a2 from and how much? If you can i like to see pics.
Old May 28, 2003
Spider883's Avatar
9K Redline Owns U
how much are they?
Old May 28, 2003
All Eyes On Z
I hope they work. I thought it was the RSX one.
Old May 28, 2003
Zzyzx's Avatar
Autocross Junky
A little off topic, but I was checking out the Different top end suspensions for our car, mainly Tein Both the SS and Flex and The JIC jic flt-a2 . the SS is the weakest of the spring rates, at 336F/448R for the civic model and 448F/559R for the RSX. next up is the jic flt-a2 at 450F/506R for both the RSX and Si versions. lastly the Tein Flex is rated at 448F/559R the same as the SS versions for the same car. It will be interesting as to which setups jic flt-a2 Vs Tien Flex will enhance our cars performance the most. both have taken different approches. Tien going with a more agressive spring rate on the rear (i assume to get as much weight to the back in corners) where Jic went with a weaker back but a stronger front. On paper it looks like the Tien will help get the back to rotate better(less understeer or possibly Oversteer) where Jic looks to have taken a more moderate route (possibly more Understeer Vs. Tien) Both the jic flt-a2 and the Tien Flex cost about the same $1800-$1900.
Interesting..........
B&G is not listed here because they dont publish the spring rates of their suspension.
Old May 28, 2003
VNlilMAN's Avatar
The Standard One
you got jics??? daaaamn thats sick foo...
EP3.. only thing you might have a problem with is alignment. aswzero had a problem with it. something to do with the tie rods. ya i know if it was for the DC5 you would have to shave 1mm of each side of the lower rear bracket. damn thats a nice setup tho, take pics of it if you can
Old May 28, 2003
All Eyes On Z
That's what I was trying to point out. I forgot to mention that it was the toe angle he had an issue with.
A little toe out ain't bad if you're racing though it'll cause more wear on the tires. But for street, it's not necessary.
Old May 28, 2003
Your Parts Guy
i forgot my dam key for my locking lugs so we couldnt put them on....im so pissed. i am going first thing in the morning to do the install and will have pics soon after.
zeil motorsports (importer of JIC-Magic) says that these will fit the 7th gen coupes and sedans without modification. i gotta say these things are beautiful i cant wait to install them.
Old May 28, 2003
Your Parts Guy
ya they were sitting in the box at the shop teasing me.
Old May 28, 2003
Your Parts Guy
EP not RSX I didnt know which one they sent when i started the thread
---slammedBlueEM2---
the front lets you adjust the camber not sure about the rear didnt get to see them yet.
--spider883---
cant post what i paid.
Old May 28, 2003
All Eyes On Z
For the rear you need a camber kit. That's the only good thing about our stock front suspesnsion compared to the traditional 4-wheel double wishbone is that you can adjust the front camber with the JICs.
Those coilovers retail for $1,980 as per JIC-Magic.com.
I can't wait for you to put'em on. I want to be 100% sure that the EP3 ones work.
Old May 29, 2003
Your Parts Guy
couldnt install my friend had work to do but i have the coilovers in a box in my trunk ill take pics after work.
Old May 29, 2003
VNlilMAN's Avatar
The Standard One
damnit hurry up.. lol i think i'm more excited about this than you are...
btw people at clubrsx.com got theirs for 1600.. i'm sure the si's are the same..
Old May 29, 2003
Your Parts Guy
Here's a shytty pic for ya. They are definitely going on Saturday morning at 9 am no excuses. We couldnt do them today cause I had a suprise walk-through on our house that my fiancee and I are having built. I'll take more/better pics after work.
Old May 29, 2003
Your Parts Guy
pics as promised...
Old May 29, 2003
Your Parts Guy
another...i am very excited to install them im just having bad luck everytime i try to.
Old May 29, 2003
ViNRoCk8's Avatar
#1 S2000 Fan
those are hot, that is the next thing I am buying. An ill set of coilovers
tell us how the ride is on saturday. Good Luck
Old May 30, 2003
All Eyes On Z
I'm sure the ride quality on those is nothing less than impressive, but I am sure dober will say something along those lines.
It gets no better than JIC-Magic. And that is in my unbiased opinion.
Old May 31, 2003
Your Parts Guy
We installed them (EP - FLT-A2) this morning and I've been driving around on them all day. I can barely get a finger in there and the rear is tucking a little tire. I think they are without a doubt the best modification i've done so far.
Of course when I went for the first drive I really put the JIC's to the test. They performed just like I would expect them to, exceptionally well. I have the damper setting on about halfway between the hardest setting and the softest setting and it handles like a dream. I went over bridges that gave me whiplash before with my neuspeed race springs and it felt like stock. Also, steering the car was ten times easier than it was before. I think there is a little oversteer, I need to get a alignment bad. When taking corners at high speeds the car seriously feels like a go-kart, very minimal body roll and i have no other suspension mods. Another thing that I noticed is when taking off from a dead stop the car stays planted and doesnt jerk back like it used to. I think that will make a little difference next time at the track : )
Here are some pics I took after the install. I will take my wheels off tomorrow and take some more pics.
EDIT- Installation was a breeze we took our time and finished in two hours and thats with rebalancing my wheels and tuning the JIC's
Old May 31, 2003
Your Parts Guy
anotha from the back...
Old May 31, 2003
Your Parts Guy
camber adjustment at my fingertips....
Old May 31, 2003
TOOLOWCIVIC's Avatar
Damn thats sweet. I want those. How low can they go??
Old May 31, 2003
Your Parts Guy
.5 to 3 inches....you can tuck the ish out of the wheels!!!!!
Old May 31, 2003
So is the ride bouncy or what??
Old May 31, 2003
Your Parts Guy
not at all with the setting i have right now they ride better than stock. when i hit bumps they rebound instantly. i could stiffen it up a little but i like the way it rides for daily driving.
Old May 31, 2003
All Eyes On Z
dober... I am so jealous... if you didn't live on the opposite coast of me, I'd hunt you down.
Sweet - sweet - sweet. You mentioned performance but forgot ride quality. But when you do give us some info on ride quality, tell us how it rides/handles on various settings.
And I'm extremely glad that Ziel made it work on the coupes/sedans without modifications.
Car looks good, too. No doubt they can go lower than Teins.
JIC-Magic.
Old Jun 1, 2003
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Wow, those look nice!
