Parts required for RSX-S brake/suspension swap?
Old May 21, 2003
cosmo's Avatar
cosmo is an unknown quantity at this point
What all parts would be required to do a complete swap of the brakes and suspension from a RSX Type-S into a LX? Also, how much fabrication would be required? Would it be worth it? Thanks for looking.
Old May 21, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Search "Rear disc conversion", We go through this every week, or PM DC5@EM2.. he has an entire ITR suspension is his car. There's someone who has a set of DC5 Tein Flex coilovers, it all bolts in. Just buy a wrecked RSX and pull everything attached to the suspension off of the car.
Old May 21, 2003
cosmo's Avatar
So everything should just bolt up? I mean the WHOLE braking system, will I need the master cylinder too? Any pictures/info of your swap would be greatly appriciated when your done.
Old May 21, 2003
Jap-Euro Fusion
I haven't done it. Nowhere in what I said did I claim to have done it. I gave you the screen name of someone who did. PM him. If you have RSX hubs and spindles, then the RSX brakes will fit, you will also need atleast 16" wheels. The lower control arms of the Civic are the same as the RSX ones, the RSX struts and springs are stiffer, but they fit into the Civic with minimal modification (I think I remember one of the holes needing to be enlarged), and all the geometry is the same. Search for brake conversion... there are parts lists posted...
Old May 21, 2003
cosmo's Avatar
Yah, I searched but they mostly talk about aftermarket pars (AEM or Willward). Sorry, I missunderstood what you said.
Old May 22, 2003
HondaLuver's Avatar
Its a celebration bitches!
while your at it ripping every suspention item off a totaled rsx, just get the engine also...
Old May 23, 2003
SlammedBlueEM2's Avatar
All Eyes On Z
Worth it? I dunno... let me think.
For the front, you must have RSX front axles and they are not cheap. In fact, you'll be spending well over $1,000 for both of them. I learned that the axles from an Si hatch actually cost more than the ones from an RSX but I could probably guess why.
I feel this would only be worth it if you want to run a serious braking set-up for your car since upgrading the RSX brakes would offer better results but that's even more money but only worth it if you're serious. However you could still have great brakes overall if you put your money into what you already have. I would rather get the rear disc brakes from a new Si and/or run a big brake set-up in the front. It would be very cost efficient compared to doing a complete conversion. SSBC has a rear disc brake conversion providing your car is wearing 16 inch rims or larger.
On the other hand, your LX does not have ABS and unfortunately, I dunno how that goes into play but I'm sure it would still work.
Old May 23, 2003
All Eyes On Z
Oh yeah, as for springs, you need the RSX tie rod ends for your stock tie rod. That's all there is to it. Doing the springs/struts is easier than the brakes. The rear is easy, the front is a lil different.
Old May 26, 2003
FaintReality's Avatar
FaintReality is an unknown quantity at this point
The rsx-s braking sucks... My 00 celica's braking was way better!
Old May 28, 2003
speed werx's Avatar
speed werx is an unknown quantity at this point
just get the rear si disc assemblies and hubs. through me they are like 700 shipped new. i have yet to try it. but its identical in the diagrams
Old May 28, 2003
ViNRoCk8's Avatar
#1 S2000 Fan
You don't need 16inch wheels for those right. You could use 15's right???
Old May 29, 2003
All Eyes On Z
You can use 15s for the Si... because the Si comes stock with 15s.
I forgot to mention, you need the RSX intermediate driveshaft with the rest of the front axles but there's nowhere it's gonna fit without having a K-engine under the hood.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
doncarbone
Jun 8, 2015 03:37 PM
SoyerOner
May 11, 2015 09:46 PM
cloudguy
Apr 28, 2015 05:02 AM
