log style manifold vs 4-in-1 style manifold?
What are the advantages / disadvantages of each? I am curious to know if one is better than the other (ie: we have 1 turbo kit with a log manifold advertised here, and another one with a 4-in-1).
I realize that the 4-in-1 will allow for faster spool up of the turbine, but is there any other advantage to it? If you have a T25BB vs a T3, the differences should almost negate each other......
Former Sponsor
the purpose of a log manifold is to make it easy and cheap .it performs the basic function of getting the exh. to the turbo.the down side of a log manifold is the presure spike of all the exh. pulses coming together happens in the manifold instead of inthe turbo housing.this causes the manifold to run hotter and more likely to crack,loss of heat to drive the turbine,increase of back pressure at the head,and offers no scavenging of the cyliders at preboost and low boost situation.
a four to one manifold scavanges exh. out of the head at low boost and preboost just like an after market header. this allows more exh. out of the cylinder during the exh. stroke whitch allows more fresh air and fuel in on the intake stoke.the four to one also increases heat and presure at the turbo thus increasing spoolup time while reducing back presure at the head
the four to one allows you to run a larger more efficent turbo without suffering brutal turbo lag
So essentiallly what you are saying is that with a 4-in-1 header each chamber is isolated from the others, thus decreasing back pressure into the adjacent firing chambers? Or in layman's terms - a more effecient design for maxumum performance.
Thanks for the reply!
Check this out, for those of the engineering mindset:
http://www.awe-tuning.com/media/pdf/...comparison.pdf
Its an excellent paper I found which describes what SFPower has said - only with photos.....
Good read...
Good read...
Good read...
Good read...
jdh022764
18
Nov 3, 2015 06:44 AM
Touge
Sep 23, 2015 11:19 PM
Touge
Ottawa
Sep 23, 2015 11:14 PM
Mannimarco
Sep 7, 2015 10:01 PM
