boost?
Tomotor
boost?
with graduation on the way, and that means money.. im seriously considering to go boost. i found a kit for $2,100 which would fit my needs. im only going to run around 4 or 5psi since my cars my daily driver. but this all depends on how much i get for graduation.
so does anyone know of a really trustworthy turbo installer/tuner is? would tim be a good guy to take it to?
Re: boost?
I just posted on xceed about the kit. I think it sucks to be honest. For over 3 grand you can get 56%? MAYBE Well, for a grand I can get 35, 50, or 75 percent from nitrous and only use it when I want to instead of my engine getting boost all the time and putting constant strain on everything from my pistons to my head gasket. Just not sure about it for our stock engines. I am curious to see what the xceed turbo freaks say.
Tomotor
**** Edgar! Turbo and NOS on our stock engines you better invest in cell phone to call a tow truck when she blows!
This will be our challenge. You guys buy and install the turbos then i will buy and install the NAWZ and we will run at Milan. Deal?
Tomotor
yea, i think max psi on stock engine is 7 or 8, and that puts you up around 220~240. but thats too much for me to risk, so im keepin it around 5. but if you get turbo+nitrous, you'll probably have to build up your internals.
If you find a "kit" Just install it yourself. Also, Is this kit intercooled? 4-5 lbs of boost is real low. If you front mount it, and can keep up fuel/and ehxuast u should easily handle 11-15 psi daily driven.
Another note, try 2 stick with one type of Forced Induction. There is no need for no2 with a turbo. Think diffrent! How about, t3/t4 turbo set-up with larger injectors/fuel pump/headers/downpipe/cat-back with a sidemount/or front Mount Intercooler with say a Co2 Sprayer kit infront of the intercooler..
Tomotor
Michelle2006
Sep 19, 2015 06:09 AM
Tommy Cohen
Jul 22, 2015 07:54 PM
