DIY: Schroth Rallye 4 Harness Install
Old Apr 30, 2003
CarbonFly's Avatar
Product: Schroth Rallye 4 Harness
Description:
The Schrothe Rallye 4 is designed for the enthusiast who is looking for a DOT approved 4 point, 2" wide harness with the simplicity of a traditional push button release. It is equipped with Schroth's unique asmŽ system, which reduces the risk of submarining. A quick-release buckle enables you to disconnect the tail strap, allowing occupants easy access to rear seats when the harnessbelt is not in use.
This harnessbelt is designed to mount to the two stock rear seat lap belt anchor points (the 'D' and 'E' points). It MUST be installed with a SCHROTH tested and approved seat which includes most stock seats having a single or dual post adjustable headrest and nearly all aftermarket 'racing' seats.
Where to get the product:
http://www.soloracer.com/rallye4.html
THIS IS THE ONLY STREET LEGAL, 50 STATE/DOT APPROVED HARNESS
Supplies needed:
- Schroth Rallye 4 Harnesses
- 14 mm socket
- 10 mm socket
Step 1:
Begin by removing the rear bench seat to get to the bolt points for the harnesses. The Schroth harness bolts straight to the stock positions. No modification is needed.
Use you 10mm socket to remove the bolt indicated below. Then just pull out the bench seat.
Old Apr 30, 2003
CarbonFly's Avatar
Step 2:
Attach the rear straps to the bolt positions(indicated by the green circles). You can go ahead and attack the driver side rear straps on the other side at this time too.
Use the 14mm socket to undo and redo the bolts for the belts.
Old Apr 30, 2003
CarbonFly's Avatar
Step 3:
Using the 14mm socket again, unbolt your seats so that you may gain access to the stock buckle. Unscrew the buckle from the bracket and place the lapbelt onto it. Re-tighten the buckle back on to the bracket. Bolt your seat back down tight.
Old Apr 30, 2003
CarbonFly's Avatar
Step 4:
Using the 14mm socket, unbolt the rod that holds the stock shoulder belt. Place the other end of the lapbelt on it and re-tighten the bolt.
Old Apr 30, 2003
CarbonFly's Avatar
Step 5:
Attach the rear harness to the front harness by clipping them together.
Old Apr 30, 2003
CarbonFly's Avatar
Step 6:
Adjust the straps so that they are comfortable yet tight at the same time.
RINSE AND REPEAT FOR THE OTHER SIDE
Old Apr 30, 2003
CarbonFly's Avatar
Old Apr 30, 2003
prototype's Avatar
x-factor
daym that looks hot!!!!!!!!! i envy u
Old Apr 30, 2003
RedDragon333's Avatar
looking good FLy once again a great DIY. Not too hard for them looks of it
Old Apr 30, 2003
4bangin's Avatar
looks great. what is submarining? is that if you flip the car or roll it over you still curl forward like with the stock belts, since you dont have a roll bar?
Old Apr 30, 2003
CarbonFly's Avatar
asmŽ is the abbreviation for anti-sub-marining, a mechanism created by Schroth to reduce the risk of submarining or sliding underneath the lap belt. Submarining can cause serious, even life threatening injuries to legs, spine and internal organs. How does asmŽ work? The device is positioned on the in-board strap of Schroth's double-shoulder harness. When the energy converter is deployed (caused by dynamic forces of instant deceleration) it forces the driver's torso and hips to rotate slightly into an asymmetrical posture which tightens the lap belt milliseconds faster.
Old Apr 30, 2003
4bangin's Avatar
oh ok. thanks.
Old Apr 30, 2003
cdmx's Avatar
your seats look sooo hot...damn thats nice fly
Old Apr 30, 2003
cdmx's Avatar
show us a pic from the front outside the car
Old Apr 30, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
this may sound dumb but what happens wen someone wants to use the rear seats? they just unbuckle the harness? then what? you have to use the stock front and driver seatbelts?
Old Apr 30, 2003
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
How comfertable are those belts, and where does the buckle sit, it looks as if it would be across your legs right now, and do they do a good job of holding you in place, NICE DIY btw, those seats look tizzight (i'm a silly white boy...)
-Mark
Old May 1, 2003
CarbonFly's Avatar
Schroth thought of everything when designing these belts. To carry passengers in the back just unclip the belts. See the pic below....
Old May 1, 2003
CarbonFly's Avatar
-Mark
They are comfortable and do not cut into my skin. BE WARNED, If you don't like enclosed spaces or have a fear of being held down then these harnesses are NOT for you.
The Harnesses are made to hold you still, upright, and tight into your seat. This harness is not a show piece. It is an actual functioning harness used by many race car teams(usually autocross).
If you do it right then the buckle and lapbelt will be across your legs and hips. When getting in the seat always tighten the lapbelt into place first and then tighten the shoulder straps.
It is NOT safe the have the lapbelt across your stomach or waist. This could allow you the submarine in and accident.
Old May 1, 2003
2k1civic.com O. G.
yeah i know it disconnects. but wen u disconnect it does it make the harness not functional anymore?
Old May 1, 2003
CarbonFly's Avatar
When you disconnect you go back to using your stock seat belts.
Old May 1, 2003
david02civic's Avatar
I'm The Shit
david02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusteddavid02civic should not be trusted
lol.so you kept your stock set up as well?
Old May 1, 2003
CarbonFly's Avatar
Yes, you are supposed to.
Old May 5, 2003
dragoon's Avatar
RACECAR!
Old May 5, 2003
18inchpride's Avatar
18inchpride is an unknown quantity at this point
awww ya i want those!!! how much did you pay for those!!!
And im gettin the same seats tomorrow!!! yehhhh i'll post my pics as soon as possible!!!! im soooooo excited!!!!!
can i have my stock seatbelt or do i need a harness!!!??????
JONNY
Old May 5, 2003
bickford05's Avatar
bickford05 is an unknown quantity at this point
nice dyi
Old May 6, 2003
RoadRunner's Avatar
nice DIY man, your a lot of help when it comes to doin DIY's
Old May 6, 2003
CarbonFly's Avatar
JONNY
This is where I got the harnesses........
The total cost including quick grips and shoulder pads came to $388 shipped.
Yes you can still use your stock belts with racing seats.
Old May 26, 2003
bublik's Avatar
Truehonda.com
bublik is an unknown quantity at this point
Does anyone know how to mount them onto the floor, I think I am going to try to do that. The seats in the back seem to be usefull.
Old May 27, 2003
CarbonFly's Avatar
read the DIY. They don't mount to the floor. The mount to the stock positions of the existing belts. The one strap mounts to the buckle bolt on the side of the seat and the other strap mounts to the bar where the strap is.
Old May 27, 2003
bublik's Avatar
Truehonda.com
Thank you, I know that. I mean, that it looks ghetto mounted to the back seat saying it is usable and people can sit in it. I was thinking of trying to mount it right behind the seat to the floor. Custom.
