Struts on Civic Sedan 2002
Old Apr 19, 2003
Amer786's Avatar
Senior Member
Amer786 is an unknown quantity at this point
I just wanted to let you guys know, if you are not alreadt aware, that there is a problem with the front struts on the the 2002 civics, some models anyways. I think the problem for me started for me a few months ago. I was driving down the street when my car started shaking, much like it does when your alignment it off or something. At the time it freaked me out but then it never did it again. Well now, a few months later, if I have the car in the D position in the driveway and move my steering wheel from the 12 oclock postion to either 11 or 1 oclock I get this slight thuming noise. I took it to Classic oHonda in Brampton and they told me that the struts need to be replaced. Luckiliy there are only 40Ks on the car and the warranty for the struts is 60K. Well the struts are on back order. I checked with a few dealerships and they all said the same thing, there is a problem with the struts. Apparently , when I had that vibration a few months ago, I think that was the point at which my struts were leaking, ever since then I have been noticing a really rough ride, well rougher than usually anyways. I just wanted to ask if anyone has expereicned this.
Amer786
Old Apr 19, 2003
Tank1030's Avatar
Tank1030 is an unknown quantity at this point
That is a common problem with GEN 7 Civics. You are fortunate that the problem occurs when you still have warranty.
Old Apr 20, 2003
iamfob's Avatar
iamfob is an unknown quantity at this point
there's no surprise
2002 already improved. try the 2001 shocks and u will understand how the 2001 owners feel about the ghey honda technology
i have extended warranty so my shocks covered all the way till 7 years/160,000 km
Old Apr 20, 2003
BlueTroll's Avatar
BlueTroll is an unknown quantity at this point
i drive a 02 sedan........... my car didn't start shaking...... but i know that when i turn the wheel.... i hear this clicking sound.......
Old Apr 20, 2003
Bluelle's Avatar
Bluelle is an unknown quantity at this point
had the same problem........but mine is a 2001.......had them replaced under warantee....
Old Apr 20, 2003
tekgnosis's Avatar
Ask me about your mom.
my friends have a 2002 LX sedan...same problem. the struts went gay on them, and they knew they were blown.
they went to one honda dealership and they wouldn't do anything about it (sick of filling warrantee requests), so they went home, put OIL all over the front struts, then took it to their dealership.
they then had no problem replacing them hehehe
The dealership guys were like "Wow, its really leaking!" hehehehe
I found that entertaining.
Mine (2002 LX sedan) are definitely on the way out...but its my fault for bashing the crap out of them on the goldline springs.
That's ok...Tein SS is on the way!
Old Apr 20, 2003
Amer786's Avatar
Senior Member
That clicking sound is your struts going, it is sooo annoying. Friggen things are on back order so you better get your order in now. The dealership is only fixing them if they are leaking, if you tell them you know that they are defective and demand them to be changed becuase it is an acknowledged problem by Honda, they wont change it. So roll you lil civic in there, do you need someone to help you push, I am sure we are 7thgencivic.com can come to your rescue :-)
Hey we are allowed to badmouth our own cars I guess. I might be changing my car, I wanna get a 2003 accord. I have lease on my civic, but the guy at the dealership said that is not a problem. All they have to do is find out how much I owe vs. what the car is worth. It may be a small difference on either the +/- side. What do you think about the accords? v4?
Old Apr 20, 2003
DragonAce's Avatar
DragonAce is an unknown quantity at this point
i never had a problem (w/ sportline drop)..
walked in, took the guy for a t/d cuz they couldn't find the noise..
both fronts, bearings and dampers ordered, and installed a week after..
clicking is still there, so we're looking at the tranny now (bulletin 420)
Old Apr 20, 2003
AzimuthX's Avatar
AzimuthX is an unknown quantity at this point
What are you referring as by "struts"?
Old Apr 20, 2003
babychai's Avatar
i want a baby hummer :)
babychai is an unknown quantity at this point
struts = shocks (???)
Old Apr 20, 2003
AzimuthX's Avatar
I'm confused too...
There struct bars (front and rear), where the front one is mounted from the left front suspension to the right accross the engine.
Old Apr 20, 2003
MSoft's Avatar
MSoft is an unknown quantity at this point
I keep noticing 7th gen sedans bounce a LOT when I see them going over smooth roads with slight bumps.
I felt the same **** when I had my stock shocks (I have 01 coupe tho), so I lowered it, then got konis, and you know, bouncing is gone, like magic!
Old Apr 21, 2003
Blkcivic's Avatar
I have konis too but theres really no difference, actually u can hear and feel every bump on the road ! my parent just brought a corolla and the suspension on them is amazing, u can ram up a crub and feel nothing
Old Apr 21, 2003
MSoft's Avatar
Shocks absorb the force while spring controls the compression. Strut is the assembly that encases a shock. Because the 7th Gen uses McPhearson struts, we call the front struts and rear shocks (rear is double wishbone). The bars you refer to tie the struts together on the top, but have nothing to do with being the struts.
Old Apr 21, 2003
AzimuthX's Avatar
Thanks, how bout a picture now?
Old Apr 21, 2003
MSoft's Avatar
That's because the corolla is not lowered.
If you lower your car, you expect a rough ride. Soft shocks don't necessarily equal good shocks though. The corolla may have good ride, but may not have as good cornering/steering performance as your car on Koni's.
Old Apr 21, 2003
AzimuthX's Avatar
If you want a good ride, go for a Toyota... all their line of cars have super impact absorbing shocks! That means Corolla, Camry, Highlander, etc.
Old Apr 21, 2003
HeRbaLuS's Avatar
HeRbaLuS is an unknown quantity at this point
hmm i'm just waiting for some full replacements for my shocks i hope those KYB's are released soon because my front shock is making the clicking sound already and leaking gonna go through the summer with it like that . if it gets worst i might as well try and take the springs out and bring it back to the dealer
what will happen if i leave it like that till the end of summer with the shock leaking anything bad going to happen???
Old Apr 21, 2003
MSoft's Avatar
Just bad ride.
Also, a note, ppl keep getting confused and say the shocks make a nice ride. The shocks actually just dampen the compression. The springs are what controls the ride quality. Even though it's a two-sided issue (i.e., it takes good shocks to make good springs ride good), it starts with the springs. If you are getting a really rough ride, or even notice a bad ride with the Koni's, see if you can get better springs. Or a new car, lol.
Old Apr 21, 2003
profurious's Avatar
I Am The Chosen One
profurious is an unknown quantity at this point
had my struts replaced, man were they ever a pile of sh_t.
Old Apr 21, 2003
HIGHLYreflective's Avatar
HIGHLYreflective is an unknown quantity at this point
is this problem happening to all 2002 sedans or only the ones that have been lowered?
Old Apr 21, 2003
DragonAce's Avatar
all..stock or lowered..
coupes too..
2001/2002
Old Apr 21, 2003
if that's the case why isn't honda doing a recall on all 2002 sedan/coupes?
when i called my dealership about this strut problem the guy had no idea what i was talking about.
Old Apr 21, 2003
DragonAce's Avatar
probably because it's not a safety thing..ergo, no recall..
guess they figure they'll fix them when they see them come in..
it's not a 100% problem, but is occuring on the 2001/2002's
what i meant by "all" is lowered and stock as that was the question that ya asked..
which dealership btw??
Old Apr 21, 2003
MSoft's Avatar
It's not a badly designed strut. If anything, McPerson struts are used in many high-end cars and race cars.
The problem is Honda adopted such a design to save engine space, but went with a "softer" strut to make ride better. And because they had to cut corners in part prices because of the cost of a redesign, they had to use cheaper shocks. This is also the reason they used returnless fuel technology. (You will even notice that fuel is not forced, can even hear the gas trickling down the pipe if you go slow enough, cheezy)
It's a great car, just has a lot of great problems/misdesigns as well. +10 -10 = 0, we're at square one.
Old Apr 22, 2003
Amer786's Avatar
Senior Member
I think a recall would involve some negative press, that Honda does not want. This way, if the problem comes up they fix it and if not then they hope that it shows up after the warranty has expried.
Old Apr 22, 2003
f*ckers! in that case i will damage my struts on purpose to have them replaced before my warranty expires.
btw: when they replace them will they be the exact same struts or different, better ones?
i called ideal honda btw.
Old Apr 23, 2003
iamfob's Avatar
dragonace: so your car is lowered with sportlines and u got the struts replaced under warranty still? if yes then can u please tell me which dealer and i will go there cuz i am running with neuspeed and i dont bother taking them out then bring the car for replacement struts then slap my lowering springs back on...such a hassle
Old Apr 23, 2003
MSoft's Avatar
I think they will replace with the same strut. Otherwise they'll have to replace *all* your struts, and no they won't do that.
CarStuff
Dec 6, 2020 12:52 PM
vtec92
May 4, 2017 03:20 AM
aus10
Apr 13, 2015 09:26 PM
Lightman
Nov 10, 2001 06:44 PM
Crash2002
Oct 26, 2001 05:02 PM
