Splinedrives & factory lug wrench
I rotate my tires myself every oil change, and are using one of those traditional four ended lug wrenches. I have aftermarket wheels and tuner lugs. I never have used the factory wrench(or jack) my car came with. I recently discovered that this factory wrench does not accept the Splinedrive keys. Since my four ended wrench stays in the garage, I would have been screwed if I'd had a flat somewhere. It just did not imediately occur to me to check this.
Just wanted to pass this along in case someone out there is doing the same thing.
I invested in a cheap 1/2" torque wrench and socket that I carry around instead of 4-way lug wrench. Much easier to remove and install plus I can get the torque setting proper.
Originally posted by InanimateCarbonRod
I bought one of those 4 ended lug-wrenches today for my trunk.
FYI:
Factory Lugs = 19mm
McGard Splinedrive Key = 21mm
(I think.....)
FYI:
Factory Lugs = 19mm
(I think.....)
You are right the factoy lugs are 19mm, and I guess your key is 21mm. You can goto a discount tire and ask for a tuner lug key, they should fit and they have both a 19mm and 21mm end on it.
