honda alarm
Old Mar 19, 2003
Civicly02's Avatar
honda alarm
I have the factory honda alarm and I was wondering if anyone who does have it can put there alarm on a "silent mode" where it doesn't honk every time you turn on or off the alarm. The horn is getting rally annoying
Old Mar 19, 2003
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
yes. There is a small round button a little bit above where you pull your hood. Press and hold on the button for 5 seconds and you will hear 2 honks and your flashing red alarm light will be lit steady. To reset, follow the above instructions again to reset to deafult. Keep in mind that if your car ever gets broken into, your alarm will not sound cause you have disabled the honk. All you see is flashing lights and no honking.
Old Mar 19, 2003
sg2kca's Avatar
sg2kca is an unknown quantity at this point
hahaha well then theres really no point of doing that then lol. Thats why I have an aftermarket alarm, cute lil chirps when I arm and dissarm.
Old Mar 19, 2003
hypnotic7thgen's Avatar
hypnotic7thgen is an unknown quantity at this point
if you can't even hear your car getting broken into then what fun is that?
Old Mar 19, 2003
Krepoort's Avatar
Krepoort is an unknown quantity at this point
Well, you do this only when you wanna disable the entire alarm system, not just the horn.
-Kre
Old Mar 19, 2003
Perhaps he wants to claim insurance...
Old Mar 19, 2003
Civicly02's Avatar
naw I was just sayin when I go to someones hous or something and I don't want to wake up the whole neighboorhood I want to put it in silent mode. My horn is freakin loud when i arm it. Everytime I arm it and a car is passing by they stop like I was honking at them or something
Old Mar 21, 2003
txtadik's Avatar
txtadik is an unknown quantity at this point
my factory alarm's like this...
i press the lock button once (the alarm is set and doors are locked)... a second time, the puny honk horns once (the alarm is still set and the doors are still locked) ... so basically the first time i press the button, the arming is silent
Old Mar 21, 2003
txtadik's Avatar
Old Mar 21, 2003
Dr5D's Avatar
i think im haveing deja voo.....
but i think my factory alarm did the same thing as his/\, push once no honk, push twice honk
Old Mar 22, 2003
born2xLr8's Avatar
The only reason I got a factory alarm was because no wire cutting/stripping would have to be done. And ditto to the push twice to honk thing.
On another note, txtadik, your avatar is disturbing...
Old Mar 22, 2003
txtadik's Avatar
lol! that's just two smilies shaking champagne bottles
Old Mar 23, 2003
cvc2k2's Avatar
cvc2k2 is an unknown quantity at this point
what honda gives you is ussually a standard keyless entry system. It is not an alarm. When you press the button twice, it is just a confirmation chirp telling you that your doors are locked. If you still think your keyless entry system is an alarm, try kick your tire and see does it go off.. or even better yet, sit in your car, "ARM" your keyless entry, and then open your door by unlocking it manually.
Old Mar 23, 2003
Dr5D's Avatar
whats your point? doesnt honda sell somthing better than keyless entry? isnt that what is being discussed? im confused.
Old Mar 23, 2003
Dr5D's Avatar
oh, and txtadiks image is disturbing, yet funny
Old Mar 23, 2003
VTECTypeR's Avatar
you can get an alarm with the keyless entry it costs extra but you can get it. I want to make it silnce to but I cant get it done.
Old Mar 23, 2003
cvc2k2's Avatar
my point that it isnt an ALARM! it is a keyless entry system! if you find the button to disable the honks, it will still function exactly the same.. except the honking!
Old Mar 23, 2003
japercraper's Avatar
japercraper is an unknown quantity at this point
just get a aftermarket alarm. clifford matrix rs3 is the ****.
Old Mar 25, 2003
hankscorpio's Avatar
hankscorpio is an unknown quantity at this point
Just as VTECTypeR said, honda does offer the alarm with the keyless entry which is a little bit more. I have it, IT IS MORE THAN JUST A KEYLESS ENTRY, that is if you got it. Just cause it doesn't go off when you kick the tire doesn't mean its not an alarm, it just means it doesn't have a motion sensor. It does have a 30 second cut off to the ignition system.
On mine, when i press lock once it chirps, if i press it again within 3 seconds it honks. This alarm on my car is all crazy. If i press lock twice within 3 seconds, it will no longer chirp when i lock it. Its kinda like pressing that button by the trunk release which also does the same thing. I've read the manual on the alarm and it doesn't work exactly how they say. One way to reset to change different modes is to hold the drivers door open while you press the lock button 3 times and then get in, close the door, and start the car up. Its all messed up. I have an 01 EX and it seems my alarm is a bit different than your setup.
Old Mar 25, 2003
cvc2k2's Avatar
i know exactly what you are talking about, it is called a Keyless Entry Controlled alarm. Basicly an alarm which uses your Lock and Unlock signal from your keyless entry and uses as a Arm and Disarm for the brain. However, this is an alarm system. Most standard Alarm systems, including the Keyless Entry Controlled alarm, Do not have the "motion sensor". They have Shock Sensors, ie when some1 kicks your tire or kicks your car anywhere, it will go off. What we are talking about here is the confirmation horn sounds that lets us know if the car doors are locked or unlocked. You, on the otherhand is talking about an Keyless Entry Controlled Alarm. Totally differant. You have the added option, they dont. Simple as that. Anyways, here are the specs for a DEI product named Hornet if any1 is interested. Dealers use the same alarm, but DEI differentiates their products by changing the name to Automate. By doing so, their car dealers can exclusively sell the brand Automate making seem like it is a Dealer Item. It is all economics and marketing...
Hornet 700T
700T Security System links to your Original Equipment Manufacturer (OEM) remotes! Don't throw away your factory remotes! Add on to your factory system with the Hornet 700T. Upgrade your factory remote control keyless entry system with Hornet convenience and security features while still utilizing your factory transmitters. The 700T comes with:
Status LED
Parking light flash
Access sensors
Panic Mode
Stinger DoubleGuard Shock Sensor with Warn Away
Remote Valet
Revenger® six-tone siren
Delayed accessory output
Ebay ussually has these Keyless Entry COntrolled Alarms. Try searching Automate, Auto mate, and Keyless Upgrade.
Old Aug 12, 2003
syndrome's Avatar
syndrome is an unknown quantity at this point
could someone please tell me where my silent button would be? I drive a 01 civic coupe EX, someone on here said the button is located just above the hood popper but I checked everywhere and found nothing but the little storage compartment, somehow I put it on silent mode and now I have no idea how to take it off.. can someone help please?
Old Aug 12, 2003
cvc2k2's Avatar
what type of an alarm do you have? try checking the users manual. you might have put it in Valet mode.
Old Aug 12, 2003
syndrome's Avatar
Its hondas own factory POS alarm.. I can't find the manual for it and dont know if its in valet or not because im just not that smart lol.. but I do know the lock on my trunk release isnt working apparently if that has something to do with it
Old Aug 12, 2003
cvc2k2's Avatar
maybe your trunk latch is locked. try unlocking it and use your alarm.
Old Aug 13, 2003
syndrome's Avatar
yeah tried that.. nothing happened, I remember sometimes when I tried to set the alarm with trunk open it gave me like 3 quick beeps, like I did something, but it never disabled my alarm like this.. I really would hate to take it to the shop just for something I can probably fix myself
Old Aug 13, 2003
erica02civicCPE's Avatar
erica02civicCPE is an unknown quantity at this point
hm. not sure. with my 02 LX, if i hit the button once the lights blink and lock the doors.....two hits, you get the lights done once more and the annoying horn beeps.
Old Aug 13, 2003
syndrome's Avatar
yeah thats what I use to have lol, now I just listen hard enough to hear the power locks
Old Aug 13, 2003
cvc2k2's Avatar
dealer should warranty it.. you have nothing to lose but a little time...
MamaBear2015
May 3, 2015 02:17 PM
Linda0818
Apr 23, 2015 11:30 AM
jessicakaybby
Apr 20, 2015 12:11 PM
Bartkat
20
Feb 19, 2002 01:29 PM
justheman
Dec 28, 2001 11:19 PM
