will our chasis last with aftermarket springs??
Old Feb 22, 2003
Kimo's Avatar
Kimo is an unknown quantity at this point
Honest question guys, a mechanic came here and took a look at my 4door civic.. i've got nespeed sport, stock shocks, stock everything. anyways, the mechanic said aftermarket springs are too hard for our cars.. they'll eventually cause damage on the suspension system n destroy parts like the front towers - plus you're ride suffers too.. now i'm in doubt with my springs [IMG]i/expressions/face-icon-small-confused.gif[/IMG] he added that its better to smply cut youre stock springs since they are not to stiff for the car's suspension system... need your help guys? any comments
thanx so much
Old Feb 22, 2003
Spider883's Avatar
9K Redline Owns U
Quote
[hr]Originally posted by: Kimo
thanx so much[hr]
that mechanic is a dumbass.. i had neuspeed sports for a year and nothing bad happened and there are people that have had springs for way longer then what i had them and they have said nothing bad.. and cutting stock springs is very bad
Old Feb 22, 2003
robbclark1's Avatar
Retired suspension supermod.
I agree with spider. If you are worried about your chassis get strut/sway/tie bars and u will be all good, but that mechanic is just plain dumb.
Old Feb 22, 2003
EternalVTEC's Avatar
EternalVTEC is an unknown quantity at this point
sounds like a 70's version of a ricer
Old Feb 22, 2003
Kimo's Avatar
haha yup the mechanic looks pretty old [IMG]i/expressions/face-icon-small-tongue.gif[/IMG] .. i guess il be keepin my lowering springs then [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Feb 23, 2003
dacivic's Avatar
dacivic is an unknown quantity at this point
Just make sure you get rear camber kit you should be good to go. You should also expect to change your shocks to an aftermarket one in the next 6-12months(appox.)
Old Feb 23, 2003
Kimo's Avatar
a camber kit? do i realy need it? i'm not dropping that low, only 1.75f and 1.5r ... the wheels arent even inside the wheel well yet ...i've got 1 1/2 finger gap up front and i guess 3 fingers at the back.. i'm planning on changing my wheels to 16" but with 195/55/r16 tires.. what do you guys think? do i still need a camber kit? ... I had the car aligned after the installment of my springs
thanx
Old Feb 23, 2003
ASWZero's Avatar
ASWZero is an unknown quantity at this point
Thats what you think. How many people hear tested the limits of their car? After a couple of months(and after a couple of upgrades later) test the limit of your car again. Since we drive our cars on the street, eventually withour stiffening our cars, the handling will slowly decrease. My car handles as good as it did when I had the NEx coils and stock tires.
As for the 70s version of a ricer, they where into racing stripes and flames/flares. All the "HOT" rodders had to worry about was the rear axle shifting out of place. The solid frame cars are about 125% more stiffer than unibody cars. Unibody cars are meant to Flex, twist, and cushion the passengers in an accident(crumple zones, anyone?). You guys cannot say anything against this until you get your car aligned and balanced(balanced at all four tires) and see how far off your cars will be. But who here has the money to go that? Someone told me that it was about $1000(minimum) to get it balanced and caged. What's the use to getting it measured out if you do not fix it with reinforcements?
Old Feb 23, 2003
Kimo's Avatar
Quote
[hr]Originally posted by: ASWZero
As for the 70s version of a ricer, they where into racing stripes and flames/flares. All the "HOT" rodders had to worry about was the rear axle shifting out of place. The solid frame cars are about 125% more stiffer than unibody cars. Unibody cars are meant to Flex, twist, and cushion the passengers in an accident(crumple zones, anyone?). You guys cannot say anything against this until you get your car aligned and balanced(balanced at all four tires) and see how far off your cars will be. But who here has the money to go that? Someone told me that it was about $1000(minimum) to get it balanced and caged. What's the use to getting it measured out if you do not fix it with reinforcements?[hr]
Hehe sorry dude i dont really get the point that youre trying to make... do you think the mechanics right about our chasis and the supesion system like the towers and bushigns are too weak for aftermarket shocks?
thanx [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 23, 2003
eXNBP's Avatar
eXNBP is an unknown quantity at this point
Quote
thanx[hr]
Do they make 16" tires that narrow? I'd go with a 205/45 or 205/40 tire for that[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 23, 2003
flotsamm's Avatar
I read somewhere that after-market springs are usually around 20-30% stiffer on average. Someone please correct me on this if I'm way off on this, thanks.
IMO if your just adding after-market springs I would think that you would be okay for the most part, especially if you go with good reputable brand name. Sure a stiffer spring may wear out other components a little faster, but thats the trade-off I suppose.
Also keep in mind that Honda themselves have a factory performance package that they sell which includes lowered springs, though its only an inch drop. Hrrrm.. this makes me wonder why only an inch and what spring rates Honda uses for this. The inch drop could be to keep in mostly within factory alignment spec and to prevent scraping, but now I wish I knew what the spring rate is.. ack.
Old Feb 23, 2003
ummm, 1. it was a joke, and 2. by the 70's about half of the new cars had uni-bodies, the only ones with frames were the big lux cars and trucks for the most part. it started back in the early 60's with the Mustang being one of the first. if you look at the cars that were popular back then, the pony cars, ALL had uni bodies, they had front and rear sub-frames, but so do the new cars.
BTW, i woulda rather grown up in the 60's cause of the cars back then, im a domestic man at heart, nothing against imports though obviously, so if thats why youre offended you shouldnt be[IMG]i/expressions/beer_yum.gif[/IMG]
Old Feb 23, 2003
Kimo's Avatar
Quote
[hr]Originally posted by: eXNBP
Quote
thanx[hr]
Do they make 16" tires that narrow? I'd go with a 205/45 or 205/40 tire for that[IMG]i/expressions/face-icon-small-smile.gif[/IMG][hr]
YuP! theyve got 16" Rota's here in the philippines that can fit 195 tires.. i'm going for that since i want to make sure that i wont need a camber kit and that my tires are not extending outside the wheel well - what ya think? also so the ride wouldnt be that bumpy as with 17"s..
Oh and i think for 16" with 205 tires on our civics you gotta have 205/50 to keep the circumference the same as stock
Old Feb 23, 2003
Kimo's Avatar
Quote
[hr]Originally posted by: EternalVTEC
BTW, i woulda rather grown up in the 60's cause of the cars back then, im a domestic man at heart, nothing against imports though obviously, so if thats why youre offended you shouldnt be[IMG]i/expressions/beer_yum.gif[/IMG][hr]
naaa no problem dude [IMG]i/expressions/beer_yum.gif[/IMG]---
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
bhollie
Sep 22, 2015 11:08 PM
