Switched Ignition power wire
Old Feb 20, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
What is a power good wire to tap off of when the car is switched on with the key but has no power when the car is not on?
Old Feb 20, 2003
vietstylez's Avatar
last time i used the IG coil wire for my neons
Old Feb 20, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
You need some kind of punctuation in there... it's hard to understand what you want....
If you want something that is on when the key is on (and the car is not), but there is no power when the car is off, use the lighter. The Yellow/green stripe wire is 12V.
Old Feb 20, 2003
HomerSimpson's Avatar
I user the power outlet - only on when the car is.
Old Feb 20, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
there's a power source in the fusebox under the steering wheel...i discovered it installing my trunk popper...its one of those spots where it looks like something plugs into...could just use one of those insulated small blade connectors...get your tester out
Old Feb 20, 2003
kjgracing's Avatar
Quote
[hr]there's a power source in the fusebox under the steering wheel...i discovered it installing my trunk popper...its one of those spots where it looks like something plugs into...could just
use one of those insulated small blade connectors...get your tester out [hr]
Yeah, I keep blowing the 15 amp fuse right there UGH!
Old Feb 21, 2003
cdmx's Avatar
Hey i needed a place to wire my amp turn on wire, im using factory cd player.....I tried the cigerette lighter but i keep blowing a fuse...so i just hooked it up to the battery and im using a switch.........So the wire in the fuse box is the best place?
Old Feb 21, 2003
ohmysac's Avatar
i dont know about the best place...but its a place [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
pincookie1
May 4, 2015 12:22 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Dmitri
123
Oct 13, 2005 08:01 PM
Mary
Jan 2, 2002 06:42 AM
