1.3" lowering require a camber kit?
Old Feb 13, 2003
Karateman's Avatar
Karateman is an unknown quantity at this point
I just dropped my '01 Si down to 1.3" with the H&R Sport springs and the wheelwell gap with my 215/40 x 17" wheels and factory struts is perfect for my liking. Question is do I need a camber kit if the negative camber is supposedly 1 degree off from stock setup? I was told by an alignment shop that there is no camber adjustment on the Hondas and that a 1 degree negative camber is really nothing to worry about other than premature wear on the inside of the tires. 1" drop is suppose to translate to 1 degree of camber...is this true?
If you agree that I should not worry about the camber kit, then I won't. Also, the alignment shop told me not to waste my cash on the front alignment as long as the steering is straight and that lowering the car won't effect alignment too much if at all.
Opinions?
Old Feb 13, 2003
DizWikedCivic's Avatar
only 1.3", u p***y, haha im jk bro, for a 1 degree camber, you wont need one, 1 degree aint nothing
Old Feb 13, 2003
666's Avatar
666
666 is an unknown quantity at this point
I have the H&R sport on my coupe and I got a camber kit for the rear, the alignment shop was able to correct the front camber without a camber kit.
Old Feb 13, 2003
VNlilMAN's Avatar
The Standard One
ya 1.3" drop is nothing, you dont need a camber kit as it will be within spec most of the time.
Old Feb 13, 2003
Karateman's Avatar
Thanks guys!
Old Feb 15, 2003
TrippinOvaNuttin's Avatar
TrippinOvaNuttin is an unknown quantity at this point
I know nothing about suspension, so here it goes... I was thinking of buying some goldlines 1.75 inch drop all around. I dont know if I need a camber kit for this, but I was afraid to even risk it... I dont need to be buying new tires... but I was wondering how much it would cost for a front and rear camber kit all together. What would I have to buy and how much would it cost? sorry for the newbie question (i've actually been reading posts for a while just never replied to any)
Old Feb 17, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
IMO na, anything less than 2 is fine w/o camber
Old Feb 17, 2003
VNlilMAN's Avatar
The Standard One
1.75" drop is kinda debatable... i think it should be fine, i dont have one with my neuspeed sports..
but ya anything lower then a 2.25" drop i'd say get one..
you dont need a front camber kit cause of how our front suspension is. rear costs $125 shipped. front is about $20.
Old Feb 27, 2003
tRu's Avatar
tRu
tRu is an unknown quantity at this point
over time you might have to purchase camber kti becuase it gets worse and worse every time you drive because but it will wear it just a little so its no big deal but i got them anyways.
Old Feb 27, 2003
VNlilMAN's Avatar
The Standard One
its'll get worse and worse everytime you drive? who told you that? that would mean the springs are starting to sag which isnt true..
either you need it or you dont.. theres no, you dont need it now but you need it later..
Old Feb 28, 2003
god if u pep will just search
Old Feb 28, 2003
jer2k's Avatar
jer2k is an unknown quantity at this point
I have the H&R sport on my LX and just got my alignment today. I have a rear camber kit. B4 the alignment my front was pretty good but my back camber was -3 degrees. This is outside the recommeded specs.
Maybe they could have put it within specs without a camber kit. I dont know but i got one.
Old Mar 18, 2003
PunkingCivic's Avatar
I need TP for my bunghole
HERE IS A LINK TO INGALLS. THEY HAVE A ROUGH CAMBER CORRECTION CHART FOR THE AMOUNT OF DROP YOU WANT ON YOUR CAR.
http://www.ingallseng.com/performance/camberchange.htm
CHECK IT OUT.IF YOU LOWER YOUR CAR.
A CAMBER KIT IS NEED UNLESS YOU LIKE TO BUY TIRES MORE OFTEN THAN OTHER PEOPLE.
IT'S YOUR CASH!
$20 SOMETHING BUCKS ISN'T THAT BAD OF A PRICE FOR A SET OF FRONT CAMBER KITS AT NEUSPEED. WHAT COULD IT HURT. iT WILL ONLY BENFIT YOU IN THE LONG RUN.
Old Mar 18, 2003
civicvtec1ps's Avatar
Search and Learn
you wont even have to worry abtou camber problem with 1.3 drop.
Old Mar 18, 2003
Macwheels's Avatar
Macwheels is an unknown quantity at this point
No not for that drop.
Old Mar 19, 2003
EnProceso's Avatar
when i got my goldlines put on, the guys there told me that with a 1.75" drop you wont need a camber, if the degree is off its not off bad enough to wear you will get visibly uneven wear, just get an allignnment. so there ya go.
Old Mar 19, 2003
flotsamm's Avatar
When you rotate your tires take a look at the inner tread. If its wore out get a camber kit.
Old Mar 19, 2003
VNlilMAN's Avatar
The Standard One
only way to find out for sure is to get an alignment.. they can tell you if you need one or not.. but then if you get an alignment and you need a camber kit, your going to have to pay for alignment again
but ya for the most part you shouldnt need one for a 1.3" drop
Old Mar 19, 2003
MadWheel's Avatar
Premium Boosted Member
VNlilman, nice drop man. I remember when you had the eibachs, looks much better. Hows the ride compared to the pros?
Old Mar 19, 2003
VNlilMAN's Avatar
The Standard One
i had eibachs when? these were the only springs i ever had probably confused with someone else. n eh i hate the drop, looks ok in pictures but in person it doesnt even look dropped at all... i guess it has the "BMW" stance but wish it was lower...
GolNat
Jan 12, 2021 09:06 PM
JKWood
Jul 28, 2015 03:45 PM
brainwashedmc
Jul 27, 2015 10:05 PM
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
chrisjackson321
Jul 12, 2015 03:00 PM
