Why are the RPMs high when the car first starts?
Old Feb 11, 2003
robbclark1's Avatar
Retired suspension supermod.
I have been around this site for awhile and I have learned alot. One question that I have tho, is why the RPMs are high when you start your car in the morning and what makes them drop when the car is warm. Thanks!
Rob
Old Feb 11, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
Strictly emissions. The fuel burns more completely/efficiently in the combustion chamber the closer to operating tempurature it is (around 202 degrees F). So the ECU monitors the water tempurature, adjusts the idle accordingly so the car will warm up quickly, thereby reducing harmful emissions faster. Hope this helps!
Wow it's 7:02 am
Old Feb 11, 2003
Jon's Avatar
Jon
Jon is an unknown quantity at this point
i didn't know that either but thx mango
and if u guys have never noticed, while your car is on and parked, pump the brake a little bit and you will notice the rev's go up a smidgen (go up and down with each pump of the brake). i never noticed that either until i was at a stoplight in my friend's itr and he showed me.
just a stupid thing i guess
Old Feb 11, 2003
MangoEX's Avatar
Just Be
Yeah, that has to do with engine vacuum... engine needs to recover and assist the brake master cylinder (repressurize) [IMG]i/expressions/beer_yum.gif[/IMG]
Old Feb 11, 2003
Intruder's Avatar
Intruder is an unknown quantity at this point
hit the nail on the head mango
Old Feb 11, 2003
robbclark1's Avatar
Thanks Mango. that helped alot. Also if you hit the clutch, the RPMS go up too! all this stuff I have to learn.
Old Feb 11, 2003
snowboreddave's Avatar
snowboreddave is an unknown quantity at this point
HEY!!! Thats what I was going to say! [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Feb 11, 2003
Grey's Avatar
DIY King
Quote
[hr]Originally posted by: robbclark1
Thanks Mango. that helped alot. Also if you hit the clutch, the RPMS go up too! all this stuff I have to learn.[hr]
That's 'cause the engine no longer has any load on it. Yep. You can initiate a drift like this. Go into the turn, turn hard and depress the clutch. It's called clutch kick. [IMG]i/expressions/demon.gif[/IMG]
Old Feb 11, 2003
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
I always kind of wondered the same thinig, but never knew what the real reason was.
Thanks guys.
Old Feb 11, 2003
Jon's Avatar
Jon
Quote
[hr]Originally posted by: Grey
Quote
That's 'cause the engine no longer has any load on it. Yep. You can initiate a drift like this. Go into the turn, turn hard and depress the clutch. It's called clutch kick. [IMG]i/expressions/demon.gif[/IMG][hr]
thx grey, i didn't know that. i think i'll be stupid and try it later on even with fwd[IMG]i/expressions/demon.gif[/IMG]
<ahem> with no traffic of course
Old Feb 11, 2003
CIVICONBAGS's Avatar
CIVICONBAGS is an unknown quantity at this point
it's cause you need a rich mixture to start the car and the pcm makes up for the mixture with a lean command until the coils and windings get warm enough to when the car can idle normally (closed loop)... and yes it is emissions related... im a smog technician/ mechanic =)
Old Feb 11, 2003
silverghost's Avatar
silverghost is an unknown quantity at this point
Are you guys nuts? SInce the dawn of the car engines always Idel high when they are cold. This used to be done by a nifty inventon known as a CHOKE... now however itis controlled by the vehicle's ECU.
The purpose of the high idle is to allow the vehicle to reach it's proper operating temperature sooner. Thus creating the desired conditions for the emissions control system to do it's job.
The emissions control systems on a vehicle do not... and I repeat DO NOT operate worth beans before the vehicle has reached the designed operating temperature.
In short... all vehicles do it when they are cold and it is a good thing they do. (just incase any of you were still confused.)
Hope this helps!
[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Feb 11, 2003
MangoEX's Avatar
Just Be
Uhm... I just said that. (like 5 hours ago)
Old Feb 12, 2003
FALKEN's Avatar
Civicforums Junkie
Quote
[hr]Originally posted by: MangoEX
Uhm... I just said that. (like 5 hours ago) [hr]
[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
dragonsblood
Apr 27, 2015 12:28 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
Richkid23
Apr 19, 2015 12:53 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
McD
Apr 16, 2015 10:46 AM
