HP 4-1 Racing Header w/High Flow Cat Help Please. Need It in a Hurry. In the middle of the install!!
Old Jan 31, 2003
alienmonkey's Avatar
alienmonkey is an unknown quantity at this point
HP 4-1 Racing Header Help Please. Need It in a Hurry
I'm outside trying to put on the Hp Racing Header w/ High flow Cat right now and need all the help I can get fast. I have an LX automatic 4 dr. and I got the header mounted to the engine fine, but I can't get the cat piece to blolt up. I can't figure out what to do. The front Sway bar seems to be in the way. I losered it, but then you can't get it back up with the cat piece bolted above the sway bar. Anyone got pictures underneath and/or a descripton of how to get the cat piece to bolt up correctly. I did a search but couldn't really find anything and I checked the DIY by OverTheTop, but it isn't helping me with this problem.
Old Jan 31, 2003
SatansEnemy's Avatar
SatansEnemy is an unknown quantity at this point
if im not wrong i believe that you will need to purchase a sway bar for an ex.
Old Jan 31, 2003
apracer211's Avatar
apracer211 is an unknown quantity at this point
yes, i have read that too. in order for the hp w/ downpipe to fit, you must have the EX sway bar.
Old Jan 31, 2003
Quote
[hr]Originally posted by: apracer211
yes, i have read that too. in order for the hp w/ downpipe to fit, you must have the EX sway bar.[hr]
Damnit What's the different between the EX and the LX sway bar?
Looking through my Honda shop manual I can't take off the sway bar outside my house, Looks like a shop will be getting some money.
OverTheTop mentions needing the sway bar for the LX Coupe "The LX coupe you will need to replace the sway bar with EX sway bar, which can be purchased from Honda for about $100" I got the sedan though. Do I still need it? Is the sway bar different betweon the 2dr. and the 4dr. model?
Thanks for the info. I hope I can get the stock header back on I guess, but I think I stripped the nut by the alternator. Any ideas on getting it off if it is stripped?
Old Jan 31, 2003
I was just look at www.hondaautomotiveparts.com and the
LX 4dr. sway bar is (SPRING, FR. STABILIZER (22.2MMXT3.2)) the same size as the EX 4dr. sway bar (SPRING, FR. STABILIZER (22.2MMXT3.2)) it appears.
LX Sway Bar
EX Sway Bar
Old Jan 31, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
Nut remover $64.00
or this piece of junk for $17.49
Old Jan 31, 2003
instead of getting one from honda just order an aftermarket one, oh and ask and make sure that is what you need, and sorry about the luck that sucks
Old Feb 1, 2003
tAkTicS's Avatar
tAkTicS is an unknown quantity at this point
hey i had this problem too with my hp header... i have an LX coupe
i ordered the stock EX sway bar from a coupe.
the EX sway bar fits fine with no rubbing.
i also drove around without a sway bar for about a week while i waited to get it from hondawerx
juss take corners real slow and no quick lane changes and you're fine
Old Feb 1, 2003
Quote
[hr]Originally posted by: tAkTicS
juss take corners real slow and no quick lane changes and you're fine[hr]
I gave up on it last night and struggled to put it back together in the light cold rain. so a stock EX sway bar from the coupe should do it, but according to hondaautomotiveparts.com it looks like the LX and the EX sway bar are the same size though (I got links above). Since you have actually seen both sway bars are they different in size/shape? I'd just like some more confirmation to put my mind at ease.
Old Feb 1, 2003
tAkTicS's Avatar
ok the sway bars are the same size... like 25.4 mm or sumthin like that
but they are differently shaped. the EX one has more of a hump to clear the cat
while the LX one is flatter because there is no cat to clear there.
i put the EX and LX sway bars next to each other when i got them
and the EX one had its bends about an inch different from the LX
... you could just install the header, take the sway bar off
and put the EX one on when you get it
Old Feb 1, 2003
Quote
and put the EX one on when you get it[hr]
Thanks a whole lot. I wanted some more clarification on the sway bar before I spent the money and you helped me out greatly. all you help has been appreciated.
Old Feb 2, 2003
CapYoda's Avatar
Escaped Convict
if you decide to leave the front sway bar off while you're driving..
becareful during turns, and curves on freeway... the car will handle differently. and in a sense unsafe too.
you'll definitely need the ex front sway bar. runs for about 80 bucks.
Old Feb 2, 2003
tAkTicS's Avatar
np... i just went through all of this a couple weeks ago.
ya like cap yoda said. you'll need the sway bar eventually
but it can wait for a week or two. just dont take turns hard
and they are like $80 US from hondawerx, just talk to greg
Old Feb 3, 2003
One last question and I should be done. I got a 4dr. LX, so should I be getting the 4dr. EX Sway Bar or the 2dr? Didn't know if the 4dr and 2dr are different or not. Obviously since I got a 4dr. car I would be get the 4dr. ex sway bar, but I want to make sure for the purpose of the Headers/Greddy Cat Back should I be getting a 4dr. or 2dr. EX Sway Bar.
Old Feb 4, 2003
CapYoda's Avatar
Escaped Convict
same thing.
Old Feb 4, 2003
tAkTicS's Avatar
Quote
[hr]Originally posted by: alienmonkey
One last question and I should be done. I got a 4dr. LX, so should I be getting the 4dr. EX Sway Bar or the 2dr? Didn't know if the 4dr and 2dr are different or not. Obviously since I got a 4dr. car I would be get the 4dr. ex sway bar, but I want to make sure for the purpose of the Headers/Greddy Cat Back should I be getting a 4dr. or 2dr. EX Sway Bar.[hr]
sorry, but i cant help much here. i dont really know if they are different or not...
Old Feb 4, 2003
Quote
[hr]Originally posted by: CapYoda
same thing.[hr]
Thanks to everyone that has contributed. Checked my funds and I should be able to get the sway bar this week and have everything installed by the end of the month, hopefully.
I'd just like to say what a great community ths has become and what great members populate it. I tried to do as much research and searches as possible on the forums and other places, but I never saw a post mentioning the need to switch out the front sway bar.
Thanks again much appreciated all.
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
Supramk3
Jun 11, 2015 11:13 AM
brian257
Jun 4, 2015 08:17 PM
JeffSpeed21
Nov 3, 2001 10:32 AM
