Adjusting Ground Control ~ HELP
Old Jan 22, 2003
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
THere's the allen key to adjust it to lock it from adjusting the height..
i can't turn that thing....it's so tight...only turn one of them out of four..
can some body give me a hand ?
thanks
eric
Old Jan 22, 2003
Aaggie77's Avatar
Aaggie77 is an unknown quantity at this point
They say you don't have to jack up the car but I have to raise mine to move them up or down.
Old Jan 23, 2003
azn0o7's Avatar
azn0o7 is an unknown quantity at this point
I had ground controls but i can't understand your promblem? Please clarify
Old Jan 23, 2003
VNlilMAN's Avatar
The Standard One
i think you need to start working out [IMG]i/expressions/laugh2.gif[/IMG] j/p..
try extending the allen key for more leverage.. maybe find a socket wrench that fits the allen key or something..
Old Jan 23, 2003
1028CiViC's Avatar
Quote
[hr]Originally posted by: VNlilMAN
try extending the allen key for more leverage.. maybe find a socket wrench that fits the allen key or something..[hr]
is there any thing that i should spray..have tried wd40...haha..i think i need to work out..haha.
Old Jan 23, 2003
Vinh's Avatar
jack the car up in the front........
raise the coilovers up so that they rest against the top knotch and don't fall back down.....
rotate it so that the keyhole is pointing towards you.....
stick the short end of the wrench in the keyhole and so that the longer part of the allan wrench is at 3 o'clock.
twist counter clockwise 180 degrees with all your strength.....
should work....
how much is your car dropped??....mine is dropped 2.25 so the keyhole is practically hidden...
but if you have something less than 1.75....u can go out and buy the allan wrench that has a handle
and does not look like an "L" shape wrench
Old Jan 23, 2003
1028CiViC's Avatar
i haven't install the coilover yet.....i am going to soon....
but it's just hard to take off the allen screw.... i took two off..
but still two more..... i am going to buy the wrench....much easier.
Old Jan 23, 2003
VNlilMAN's Avatar
The Standard One
wd-40 might not be a good idea cause what if it becomes so loose that it becomes loose over time while driving
Old Jan 24, 2003
1028CiViC's Avatar
ok, what should i use instead of wd-40?
thanks
Old Jan 24, 2003
djmota's Avatar
they are tough when they are out of the car but when they are installed it is much easier. try slipping the sleeve over something that will keep it upright such as the handle on a floor jack or fence post. You have no leverage when you are trying to hold the sleeve in one hand and the allen tool in the other.or you can pick up one of those allen key sockets that will fit your socket wrench.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
Jul 12, 2015 11:54 AM
