Springs upside down?????
Old Jan 11, 2003
misio4's Avatar
misio4 is an unknown quantity at this point
Hi all, just wanted to ask this question to make sure I didn't get bull$h!t answer from a tuffy mechanic. They installed my springs 1.75 drop on all four and the rear ones were installed upside down. Now because I didn't look underneath my car untill couple of months later when I installed the cat back exhaust I didn't know about the mistake. But since the springs are the same diameter on top as on bottom is that something I should fix now or will I be ok. And is there a difference in the drop.
The side where the coils are close together is on the bottom and the farther apart is on top.
So............
I was pissed when I found out but I was told that it won't make any difference and that it will or might. I even called the dealer and they weren't sure but tried to sell me the honda sport suspension.
So what should I do???
Old Jan 11, 2003
SLAMMED01CIV's Avatar
SLAMMED01CIV is an unknown quantity at this point
I'm not sure if it will be a problem. I have coilovers and not springs so I have no clue. I'd fix them ASAP just to on the safe side.
Old Jan 11, 2003
zzzzzzzzzv's Avatar
zzzzzzzzzv is an unknown quantity at this point
hmm yea.. i have the same question too. i suggest calling the spring manufacturer and asking them.
Old Jan 11, 2003
XxSoVeReiGNxX's Avatar
how exactly do you know they're upside-down? wouldn't springs look the same either way? or do they have special marks (like directional tires)?
Old Jan 11, 2003
misio4's Avatar
You know it is upside down cuz the letter on it are upside down and also the side where the coils are closer together are on the bottom. They should be on top. I have nuespeed sport springs.
Old Jan 11, 2003
phlipsidez's Avatar
phlipsidez is an unknown quantity at this point
I thought I had the same problem... I couldn't find the threads that this was talked about, so I won't flame you. But if you have either the Neuspeeds of the Eibachs the tight coils on the front springs go on the TOP. The tight coils on the rear springs go on the BOTTOM. I emailed neuspeed about this too to make sure. Here are some pics of the Eibach springs being installed... you'll see that I am right....
click me
There is only one way the rear springs go in too, and that is with the tight coils on the bottom. They won't fit with the tight coils on top the way the lower perch is designed.
btw, I have Neuspeed sports
Old Jan 11, 2003
phlipsidez's Avatar
Quote
[hr]Originally posted by: misio4
You know it is upside down cuz the letter on it are upside down and also the side where the coils are closer together are on the bottom. They should be on top. I have nuespeed sport springs.[hr]
This is not true. Before installing my springs I called Neuspeed because I thought the same. They said that they had been having communication problems with the manufacturers overseas (or something like that) and the labels were printed upside down.
Don't follow the labels. Your mechanics installed your springs correctly.
Old Jan 11, 2003
CivicRicer02's Avatar
CivicRicer02 is an unknown quantity at this point
Mine have like silicon hoseon the first coils so i know that they are right><>
Old Jan 11, 2003
zzzzzzzzzv's Avatar
thanks for the info
Old Jan 12, 2003
misio4's Avatar
Thanks phlipsidez.
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
