door panels *help*
door panels *help*
hey i got a 2001 civic dx and i have those manual windows i was jus wondering if ne one knew how to remover the door panels i tries but i cant seem to figure out how to remove the **** thing that rolls the window down thanx
on just about every car i have seen ( haven't tried it on a dx 01) you'll be looking for a plastic top that pushes into the crack. that will pry off with a flat head screw driver exposing a screw that holds the crank.
if your look really close there a lil opening on the manual door handle and there a lil metal clip, just romve the metal clip w/ like a little small pryer or a something u can hook with it and pull out
wheres the opening? i look on the back of the crank...i saw a lil opening but it doesnt look like u can detatch ne thing from there i look all around but yea nuthing that iould see unless im going blind or sumthing
Quote
[hr]Originally posted by: djlunatic
on just about every car i have seen ( haven't tried it on a dx 01) you'll be looking for a plastic top that pushes into the crack. that will pry off with a flat head screw driver exposing a screw that holds the crank.[hr]
The DX also has two screws behind the inside door handle pull to remove before the panel will come off. To get to them, remove the one small screw in the pull sections and pull out that piece. You'll see them now. Don't forget to take out the screws behind the door handle trim piece at the top. After those two areas are done, take out the sail panel where the sideview mirror stick is located and carefully pull out on the panel. When it's loose, lift up and it'll come off.
If you have any other questions, ask away.
MamaBear2015
May 3, 2015 02:17 PM
BabyLX
Nov 8, 2001 09:25 AM
