What to use to cut door panel?
Old Dec 22, 2002
dru106's Avatar
ThE CoRRupToR
I want to put tweeters on my door panels since theres no where else to put it since I have an LX model. What should I use to cut the panel to install the tweeters?
Old Dec 22, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Dremel. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Dec 22, 2002
OmegaBlue2k1's Avatar
OmegaBlue2k1 is an unknown quantity at this point
Or use a circle cutter drill bit, (looks like a steel band with saw blade teeth on one end and a drill bit in the center. Get one that has the same Outside Diameter as the Inside Diameter of the tweeter mounts.
Old Dec 22, 2002
Bellz's Avatar
Check out my post back in June about mounting tweeters in the doors here. Measure the diameter of the hole you'll need to cut and get a hole saw that size. If they're flush mount tweeters, they'll hide the hole and look professional. Here's a pic of the Pioneer TS-T110's I used:
Old Dec 22, 2002
666's Avatar
666
666 is an unknown quantity at this point
A hole saw works well.
Old Dec 22, 2002
Mbow's Avatar
I installed my tweeters in the doors of my sedan right next to the door handle. My components came with stickers to use as guides for cutting the circles out. I just stuck the sticker on and took and exacto knife and scored the outline of the sticker. Then, I took a dremel and slowly opened up the hole. Pretty easy. You could try and find a circle type cutter for a drill. I had one but it was slightly to big and didn't want to spend anymore money.
You can see mine on my member's page.
theteju
Aug 5, 2015 06:59 PM
Dani1993
Jul 24, 2015 09:02 AM
orangeju1ce
Jul 14, 2015 08:32 PM
ballmich
Jul 9, 2015 11:59 AM
Spanky4269
Jul 5, 2015 09:40 PM
