List of torque specs & socket size
Old Dec 10, 2002
pdxbiker's Avatar
pdxbiker is an unknown quantity at this point
We should make a list of torque specs here so we can all use it as a reference. For example the lugs for wheels: 80 ft-lbs, strut bars 33 ft-lbs ...and so on.
We should also make a list of all the socket sizes like 10mm for bumper removal, 14mm for end links, 12mm to remove rear sway bar bushing bracket.....etc.
I guess we can either keep it here or put it in the DIY section.
Old Dec 10, 2002
JDMCIVIC's Avatar
JDM WHORE!!!
JDMCIVIC will become famous soon enough
Sounds like a great idea. I would help out but got no time, this would be a long list.
Old Dec 10, 2002
redcivic's Avatar
redcivic is an unknown quantity at this point
I second that, alot of ameture tuners don't relize how important that really is!
Old Dec 10, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
Here's my contribution
Oil Drain Bolt... 17mm
Torque= 33/29 ft-lb DX,LX/EX(Si)
Fill = 3.4/3.7 Qt. DX,LX/EX(Si)
Coupe Seat Belt Bars (The rails near the floor) - 14 mm
Old Dec 11, 2002
Grey's Avatar
DIY King
I have a couple of torque specs from the Body Repair Manual:
6x1.0 mm: 7.2 lbf-ft (lower torque bolts)
6x1.0 mm: 13 lbf-ft (higher torque bolts)
8x1.25 mm: 16 lbf-ft (lower torque bolts)
8x1.25 mm: 22 lbf-ft (higher torque bolts)
It shows a diagram telling you which are which, but it's a diagram of the major body panels. We probably won't be taking those bolts out. It's of general help to give you a guage of what torque to use though...
Old Dec 17, 2002
ironcow's Avatar
ironcow is on a distinguished road
the rear upper and front upper strut bolts 14mm deep socket
and 35 ft/lbs of torque
Old Dec 24, 2002
3rdcivic's Avatar
3rdcivic is an unknown quantity at this point
Header nuts/bolts: 12mm socket. 23ft/lbs
Wheel lug nuts: 19mm socket. 80ft/lbs
Upper strut mounts (3 nuts/side): 14mm socket. 33ft/lbs
OEM strut shaft nut: 17mm socket. 33ft/lbs
*Tip for using OEM strut shaft nut on Koni shocks: Use a 9mm box wrench to hold the strut shaft from spinning while using a 17mm crows foot socket adaptor to torque the nut.
Old Dec 24, 2002
DaCurryman's Avatar
DaCurryman is an unknown quantity at this point
The two Front Lower Control Arm Bolts (19mm hex) and
the two sub-frame bolts (17mm hex) are torqued to 76ft-lbs. (98Nm)
These are the bolts that you remove and put back when you install the Neuspeed Front Lower X-Brace Bar.
Old Dec 24, 2002
Grey's Avatar
DIY King
The four bolts holding down the shifter assembly: 16 lbf-ft
Old Dec 29, 2002
Lasher's Avatar
Lasher is an unknown quantity at this point
does anyone no the torque specs for the bolts of the lower strut and shocks respectivly. The two that connect the front struts to the rotor assembely and the one bolt connecting the rear shocK to the lower control arm? How about the bolt connecting the controll arms to the strut in front?
cukaracha
30
Jul 26, 2015 12:01 PM
hoofboy
Jul 17, 2015 04:27 PM
Genyc07
Wheels and Tires
Jul 11, 2015 05:51 PM
jzhartman
Jul 9, 2015 04:56 PM
muttleytm
Jul 8, 2015 04:13 PM
