hit curb
hit curb
i recently skidded into a curb because of all the snow and ice (front passnger)..it was nothing big,,not even goin that fast..but it did mess up my alignment..and more importantly the camber...i can actually see the postive camber....is this serious? or can it be repaired? i heard that FWD cars dont have repairable cambers...any advice?
DIY King
I'm in a similiar situation myself. You can buy a camber kit and adjust the camber that way. Although I would try to fix the camber without adjusting the kit. I have an SPC front camber kit myself, and I want to fix my camber without adjusting it. You can adjust the toe by moving the tie rods in and out. Not sure if you have to take them off of the place where they attach to the strut? I'll know soon enough because I will be trying to do a front alignment myself. I'm not sure about the camber or castor, I'll need to study the front suspension to see how to adjust those. I'll try soon enough (like a week or two) and report back the results here...
grey.,..thanks for a speedy reply....
can a camber kit correct such a drastic problem? i thought they could only correct very slight cambers....
i hope nothing is seriously damaged.
DIY King
How much is it off camber? The difference betwean my right and left side up front is about an inch when measured from the outside diameter. So my passenger side is negative 3/4" from vertical and my driver's side is positive 1/4" from vertical. Kinda sucks huh? How much is yours offset? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
DIY King
Well, the SPC front camber kit can change camber up to 1.75 degrees positive or negative. The stock camber setting up front is 0 +- .45, so even with the maximum correction of the SPC camber kit you'de get: +2.32 - 1.75 = 0.57 which is out of spec. The Ingalls front camber kit (part number 81260m there are two of them for the front) can adjust up to 2 degrees, so you could get: + 2.32 - 2.00 = 0.32 which is just in spec. I guess you could do that. Although when you lower the car you'll be out of spec again. That is if you aren't lowered yet. That's why I want to fix mine without a camber kit first, so that I can fix the camber when I lower it.
VNlilMAN: Do you know how to adjust it exactly? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
The Standard One
2.32 degrees? ouch, sounds like something is bent. is it the front or rear? if its the rear, check the control arms, i've heard of shops adjusting the camber by actually bending the camber kit(something i dont recommend) to correct the camber. maybe when you hit it, it bent the camber kit and gave you a positive camber. reason why i think something is bent... you cant really adjust the camber without a camber kit... the adjustment would be very minimal and no where close to 2.32 degrees.
as for adjusting it without a camber kit, i have no idea.. i doubt you could adjust it much without one tho, probably .1 degrees the most or something... for the front try doing this.. you know those two bolts right, just loosen both, and there will probably be a little bit of play. just put it to the position, you want and tighten the bolts. as for the rear.. maybe try the metal washer trick.. that is putting metal washers where the control arm bolts up to the cars chassis..
i still dont get why you dont want to adjust it with the camber kit tho.. cant you just adjust the camber kit to the factory position when your car is stock height? n then when your car is lowered, adjust it to the factory setting again when its lowered.
The Standard One
its the front? damn must have hit it hard.. if something is bent, a camber kit isnt going to fix it. i dunno maybe it isnt bent, a front camber kit is only $20 so i would just try it
DIY King
Quote
[hr]Originally posted by: VNlilMAN
i still dont get why you dont want to adjust it with the camber kit tho.. cant you just adjust the camber kit to the factory position when your car is stock height? n then when your car is lowered, adjust it to the factory setting again when its lowered.[hr]
DIY King
Quote
[hr]Originally posted by: StraightEdgeCivic
1.how did YOUR camber get messed up grey?
2.also,,,since i have a positive camber....if i lower my car...will the camber get closer to range?[hr]
2. Yes. If you lower it, the camber goes negative. So if you have positive camber, it'll be less positive. hehe...
The Standard One
Quote
Quote
[hr]Originally posted by: MugenRacerX
technically..your not a "StraightEdgeCivic" now.. hehehe.. hope you get yur prob solved[hr]
Balkos
Sep 11, 2015 11:39 PM
