Removing rear plastic pillar
Old Dec 7, 2002
SLeePeR012's Avatar
SLeePeR012 is an unknown quantity at this point
Hey guys, Im tryin to install my 6x9s and I can't seem to take the rear plastic pillar off.
Im using Ghostly's DIY, Bellz was really blunt and the lack of pics didnt help.
I took off my seats and all the hardware to the side rear panel. (1 plastic screw in back, 1 phillips in armrest, and the two bolts for front seatbelts.)
I mite be missing something but I dont think so.
Thanks guys!
Old Dec 7, 2002
riceboi's Avatar
riceboi is an unknown quantity at this point
the rear column?
just YANK it out from the top. it comes right out
Old Dec 7, 2002
2001CIVICLX's Avatar
2001CIVICLX is an unknown quantity at this point
Be very careful if you have tint though, and with the wiring, just be careful.
Old Dec 7, 2002
SLeePeR012's Avatar
Rear column? I donno. I always called it pillars.
They run vertical from the roof of the carpets down to the seatbelts. They are grey and made of plastic.
I cant find a way to pry it so I can yank it off.
Old Dec 7, 2002
amhtown01's Avatar
as i recall..u first need to remove your side step (connected by 2 bolts), because the side step overlaps the "rear plastic pillar.'' Once that is off all you need to do is pull on it. It is quite hard to remove the entire thing because the rear seat is in the way.
Old Dec 7, 2002
Aaggie77's Avatar
Aaggie77 is an unknown quantity at this point
Yup, just pull from top to bottom. I think there are 5 white snaps that hold it on.
Old Dec 7, 2002
KeNsHiN's Avatar
LEVA
Old Dec 8, 2002
Drivetofast's Avatar
Supercharged k20a3
Drivetofast is an unknown quantity at this point
take out everything it will be easyer in the long run to get everything to fit rite
Old Dec 8, 2002
robbclark1's Avatar
Retired suspension supermod.
pull out the little regtangular pieces that is in them first then pull them hard. trust me they will pop off.
Old Dec 8, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
Try to put your finger next to the "poppers" when your popping it out if you can. Or have someone go into your trunk and pop them out with a screwdriver while you pull on it.
OPGForce
Exterior DIY
125
May 20, 2019 04:11 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Galvezj11
Jun 17, 2015 04:13 PM
sbi
Jun 12, 2015 11:59 AM
JackTripper
Nov 7, 2001 09:04 PM
