2002 ex coupe dashboard removal HELP!
Just Be
HOw do you remove the ENTIRE dashboard of a 2002 EX COUPE? i already removed the glove box and like 20 screws but the thing seems to be held on by the airbag area, is it possible to remove the cover to reveal screws in there? Im scared to. Any tips and info would be appreciated... that thing is so difficult to take out. I am trying to replace the frontal dash piece that stretches from drives door to passenger door. some a*****e broke into my car and screwed it up with a screwdriver
Ok, first start popping out your vents, then glove box, then the piece where your cig lighter is, then radio console, disconnect the battery, then pass side air bag, driver air bag, remove steering wheel, also remove cover behind wheel, remove gauge cluster, and center console (floor) will make it easier to work. (Sounds like fun rite?) Ok, now.........as you start removing screws, try to remember where they go! (Some are different sizes) and there are about a million! J/K
The whole process took about 15 hrs! (removal, painting, install)
Good luck if you decide to do it man!
It's not that hard, just try to remember how everything goes back. And if you should happen to have a couple of screws left...........(like me)..........dont worry!! lol Just make sure the dash is st
sumoen here pm that to me
CarStuff
Dec 6, 2020 12:52 PM
Civic2002lx
Oct 7, 2015 09:17 AM
izdman
May 19, 2015 03:43 PM
CapYoda
Nov 11, 2001 05:17 PM
