SRS light---> Searched respond ASAP pls!!
Old Oct 28, 2002
RedDragon333's Avatar
ve the opportunity to get some racing seats really cheap and i was told by some people that if i replace the stock seats that my SRS light will go off...i dont want this happening but it leaves me to wonder whats gonna make it go off if i dont have the side airbags? I need to know before i buy and the deals over
Old Oct 28, 2002
JDog2001CivicEX's Avatar
JDog2001CivicEX is an unknown quantity at this point
If your car didn't come with side airbags then you shouldnt have to worry about the SRS light coming on, but what might trigger it is the connector for the noise when your not buckled in might have something to do with the SRS light to. Like to say if it was disconnected that light might come on to remind you that something is wrong with the electrical of that area.
Old Oct 28, 2002
ducksause's Avatar
ducksause is an unknown quantity at this point
I agree
Old Oct 28, 2002
Toad's Avatar
Toad is an unknown quantity at this point
also... i was screwing around with my seats and stuff while the car was on and the SRS light came on... had the dealer reset it. Did the same thing with the car off... no SRS light.
Old Oct 28, 2002
sevenincubus's Avatar
sevenincubus is an unknown quantity at this point
my srs light has come on twice already. the dealership reset it the first time but said they would have to charge me if it happened again. the second time it came on, i used the diy on how to reset the srs light and it went off. the only reason it will not reset is if there is something wrong.
Old Oct 28, 2002
my2k1vic's Avatar
my2k1vic is an unknown quantity at this point
no lights should come on if you don't have any side air bags. i have aftermarket seats and none of my lights are on. all you have to make sure is that you re-connect the wires,which are just plugs, to the seat belt harness so the seat belt light can work properly. also are the brakets that you are going to use made for this car? if not, you will loose your seat belts.
Old Oct 28, 2002
Quote
[hr]Originally posted by: my2k1vic
no lights should come on if you don't have any side air bags. i have aftermarket seats and none of my lights are on. all you have to make sure is that you re-connect the wires,which are just plugs, to the seat belt harness so the seat belt light can work properly. also are the brakets that you are going to use made for this car? if not, you will loose your seat belts.[hr]
eys the brackets and sliders are made for the car...i just wanted to make sure no lights are gonna go off
