How to jack up rear side of car?
I want to change my winter tires on soon, where do I jack up the car on the rear? I know where to put the stands, but don't know where to put the jack.
RTFM..........the owners manual will tell you.
I think its about 6 inches in front of the rear tire, there should be a slot for the jack to fit.
Well, while we're on the subject, how do you jack the ENTIRE rear at once. The manual does not tell you that. On the front there is a point on the frame in the center where there is a jack point, but I have yet to find one in the back. So where is it?
Quote
[hr]Originally posted by: klam
I want to change my winter tires on soon, where do I jack up the car on the rear? I know where to put the stands, but don't know where to put the jack.[hr]
:_ doh:
Quote
[hr]Originally posted by: Boilermaker1
Well, while we're on the subject, how do you jack the ENTIRE rear at once. The manual does not tell you that. On the front there is a point on the frame in the center where there is a jack point, but I have yet to find one in the back. So where is it?[hr]
As per the OEM manual.
If you are lifting with a floor jack and want to raise the front, look under the front of the car behind the bumper. You will see a metal pad with an arrow pointing to it. This is the recommended place to lift the entire front of the car.
To lift the rear, you place the jack under the loop underneath the car. Most would call this the boat tie down. Then you lift at that point.
Always place jack stands at the scissor jack lift points to support the car.
LionSpratt
Jan 29, 2017 11:07 PM
ej8
Apr 13, 2015 06:36 PM
