RSX Sway Bar DIY
Old Oct 19, 2002
sumama's Avatar
sumama is an unknown quantity at this point
RSX Sway Bar DIY
I think it was Mex who posted a DIY for the rsx sway bar a little while ago. Can anyone give me the link to the DIY? any help is appreciated. thank!
Old Oct 19, 2002
speed werx's Avatar
speed werx is an unknown quantity at this point
search under suspension.. i think it was there if i recall
Old Oct 19, 2002
RainRacer's Avatar
RainRacer is an unknown quantity at this point
Try these
link 1
link 2
Old Oct 19, 2002
DamnChris's Avatar
DamnChris is an unknown quantity at this point
just curious. will this RSX lower tie bar work for an 01 LX sedan?
Old Oct 19, 2002
AzNmiKex215's Avatar
2k1civic.com O. G.
what size is the swaybar on the RSX-R?? is it bigger then 19mm? bigger/thicker = better?
Old Oct 19, 2002
civicvtec1ps's Avatar
Search and Learn
Quote
[hr]Originally posted by: AzNmiKex215
what size is the swaybar on the RSX-R?? is it bigger then 19mm? bigger/thicker = better?[hr]
19mm for type s
22mm for type r
Old Oct 20, 2002
speed werx's Avatar
the RSXR sway bar is 22mm RSXS 19mm
Old Oct 20, 2002
BLUENVY01's Avatar
BLUENVY01 is an unknown quantity at this point
this is mainly opinion, but 22mm is too thick to be putting on a civic. its almost unnecessary. the 19mm sway bars are supposed to be a nice upgrade. if you are refering to the rear sway bar being installed onto the LX coupe or sedan, i believe there is drilling needed to attach the sway bar mounting brackets.
as for the installation, if you have an EX, then the links provided will be sufficient, but if you have an LX, you will need to search around some more for more RSX sway bar installs. i know for a fact that there is a DIY for the RSX sway bar onto an LX, its just that i dont wanna go searching for it since im not doing the install.
g'luck!
Old Oct 20, 2002
speed werx's Avatar
the sway bar kit i sell from the RSX typeS will fit 01+EX and 02+ LX, bolt on
Old Oct 20, 2002
2k1civic.com O. G.
22 is too much? to thick = bad for the civic? will hondawerx be carrying any RSX Type R stuff? such as the sway bar?
Old Oct 20, 2002
sumama's Avatar
hondawerx.com is a great site!
Old Oct 20, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
The RSX-S 19mm is more than enough.
I'm getting one from a clubrsx.com member for $50 with brushings.
Old Oct 20, 2002
ak's Avatar
ak
Retired Mod
Quote
[hr]Originally posted by: RainRacer
Try these
link 1
link 2[hr]
Thank you
Old Oct 21, 2002
Ken2oo2's Avatar
Ken2oo2 is an unknown quantity at this point
does anyone know how thick the rsx base model sway bar is?
Thanks
KeN
Old Oct 21, 2002
ak's Avatar
ak
Retired Mod
edited, probably 19mm too right?
Old Oct 21, 2002
DaCurryman's Avatar
DaCurryman is an unknown quantity at this point
As far as I know, both Base and Type S are 19mm. They do have suspension differences (Type S is a bit lower I believe), but the sway bar is the same.
SammySC
121
Apr 7, 2017 07:43 PM
Raiool
Oct 1, 2015 10:42 AM
rovafa2002
Sep 28, 2015 06:57 PM
speedlever
Sep 24, 2015 07:18 PM
Viczhou
Sep 2, 2015 07:55 PM
