2 Questions Guys
2 Questions Guys
1. After u clear your headlights, does your stock turn signal bulbs light up white or amber? Where I live, the car is required to have amber turn signal and before I clear mine I need to make sure they're amber or I'll have to buy amber-colored bulbs first.
2. Is it possible to get the headlights out without taking off the bumper?
Thx [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
no, u need to take bumper out first in order to take off headlight, and yes, the turn signal will not be amber after u cleared headlight[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
You can just buy amber bulbs.
You dont need to remove the entire bumper. You can just pop off the top clips under the hood, and then remove the bolt in the fender wells....you then pull the bumper out from under the headlights and fold it down....You can then remove the two screws that are hold ing the metal bracket on under the headlight and the top screw that is holding the headlight on....
They will light up yellowish. Not as white as the stock headlight. If you need orange bulbs... APC makes amber 7443's and LEDs that should keep you legal. I'm sure there are others, but I know of those.
Yes you MUST take the bumper off. it isn't hard. maybe a 15 minute job. You'll prolly need a socket extention to get the bolts under the headlight off. The right one was easier than the left, so do the right first.
Quote
[hr]Originally posted by: civicdude
You dont need to remove the entire bumper. You can just pop off the top clips under the hood, and then remove the bolt in the fender wells....you then pull the bumper out from under the headlights and fold it down....You can then remove the two screws that are hold ing the metal bracket on under the headlight and the top screw that is holding the headlight on....[hr]
No need to take off your full bumper... [IMG]i/expressions/face-icon-small-smile.gif[/IMG] Don't be afraid.
thana
Jun 15, 2020 07:05 PM
vtecbrah
19
Jun 5, 2015 09:38 PM
dosmastr
May 5, 2015 12:19 PM
zack22490
Apr 29, 2015 03:17 PM
