Removing Dealership sticker
just to make sure
Do I just keep picking at it then rip it off?
I don't want to rip the sticker off and take my paint along with it
use a blow dryer or heat gun and heat it up for at least 2 minutes, then peel it off. should take all the sticky gunk off with it. if not, use wd-40 to clean up the sticky stuff. and be sure to wax the area.
I used the dishsoap and water trick. Worked great!
Just fill a cup with water and dishsoap mix, use a paper towel to coat the whole sticker with soapy water. The dealership sticker should peel off quite easily.
edit: oh yea, and I found this trick by searching in the detailing forum. [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Mine was just a vinyl sticker that peeled right off. I goo goned the junk. If it is an emblem (raised plastic)... use a hair drier and dental floss. Heat the glue up, then slide the floss underneath to pull it off. Goo gone what's left.
Quote
[hr]Originally posted by: OyD
take is back to the dealer and tell them to take it off unless they offer to pay you for advertising[hr]
I told them when I bought my car that if there was any dealer markings on my car they'd be billed for advertising! They kindly removed them all.
After i removed the stickers...(usually just peeling them off) unless it was a badge of some sort then i would use a heat gun/blowdryer. I used Car wax and basically scrubbed with a soft towel.
mjdiaz89
Jun 21, 2016 09:26 PM
Brandon Vlasak
Jul 25, 2015 07:25 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
ballmich
Jul 9, 2015 11:59 AM
