What size tires rub/don't rub on 17's?
So I've decided that I'm gonna get some 17's for my car. Now my problem is what size tire. [IMG]i/expressions/face-icon-small-confused.gif[/IMG] I want to get 215/45/17 which is just a lil' bit bigger in diameter than the diameter of the stock tire. The problem is, that's 30mm wider than the stock tire. There's got to be some rubbing action going on there.
I would prefer the diameter of the new tire be larger than the stock diameter cause I would rather have my odometer read less miles than I actually have rather than more miles than I actually. But that's the least of my worries.
I just want to know what size tires other people with 17's have and if they rub or not. Also if you've made any mods to keep it from rubbing, like a camber kit or shaving the fenders.
If anyone has had rubbing, could you post a pic of where it rubs? That would be awesome! Thanks! [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
got a pic of it wawacito? i wanna see how it looks not lowered
edit: nevamind i just saw it in members rides....would look better lowered IMO.....i would get the eibach pro kit if decide to go for 17's
DIY King
My 215/45/17's rub in back with my Rota Attacks when I raise the car to take the wheels off. Not when I drive though. When I get an aftermarket suspension that's stiffer and lower it won't do that anymore since the part that rubs will be on the inside of the wheel where the cavity is.
My rear with 215/45/17 rubs if the camber is fairly perpendicular to the ground. If the camber is negative, you won't rub the fender, but you'll get some bad tire wear. I dropped the car down with 1 1/2 fender fingers in the rear. I'm planning to go crazy with my bat and attempt to roll my fenders. People make it sound so easy to do.
Quote
[hr]Originally posted by: DuYaKnow
My rear with 215/45/17 rubs if the camber is fairly perpendicular to the ground. If the camber is negative, you won't rub the fender, but you'll get some bad tire wear. I dropped the car down with 1 1/2 fender fingers in the rear. I'm planning to go crazy with my bat and attempt to roll my fenders. People make it sound so easy to do.[hr]
how about 225/45-17 with 1.7 "drop?
i have 205/40-17 now and it seems like i got plenty of space to add girth to the sidewall, but my rim lip shows (7.5 width) so i want some wider tires like 225.
The Standard One
you want a wider tire but why would you want a bigger sidewall? just get 225-40-17 then. the sidewalls going to be bigger then the 205-40 but atleast it wont be that big. n with 225-40-17, you shouldnt have problems with rubbing
215/45R17 Kumho Ecsta 711s on 17x7x42mm 5zigen Fighters.
Front: 1/2 finger gap
Rear: 1 finger gap
Fronts rub inner fender during bumps (like intersections where the perpendicular street is higer)
Rears tuck (my fenders are slightly rolled and tuck will depend on your camber setting)
Pic
Rear: 1 finger gap
Pic
Quote
[hr]Originally posted by: VNlilMAN
you want a wider tire but why would you want a bigger sidewall? just get 225-40-17 then. the sidewalls going to be bigger then the 205-40 but atleast it wont be that big. n with 225-40-17, you shouldnt have problems with rubbing[hr]
The Standard One
nevermind, i dont think they even make that size sorry, not too familiar with 17s. closest thing would be 235-40 or 225-35 but i think the 235 are a lil to wide and 225-35 a lil too thin.
Quote
[hr]Originally posted by: InanimateCarbonRod
Rear: 1 finger gap
Pic[hr]
Rear: 1 finger gap
Pic[hr]
Quote
The Standard One
eh, 40 isnt that small... my friend hit a 90 degree angle peice of cement going 40 mph and he cracked his rim but i've hit a couple of potholes myself and my rims/tires are still fine. the roads here in the ghetto streets of LA arent too pretty but my rims are still fine.
OptimisticWay
46
Oct 15, 2015 02:16 PM
muttleytm
Jul 8, 2015 04:13 PM
BootyDo
Jul 7, 2015 06:06 AM
Causemo
Jul 5, 2015 06:42 AM
