Looks like we can have direct port nitrous injection!
Old Jul 12, 2002
Grey's Avatar
DIY King
Here! Ooh! Now nice would this be!!! This is the best way to install nitrous. Then you don't get get something like that intake manifold accident. Maybe a 50 shot would add more power this way than the standard way of installing N2O. Our engine are supposed to have some sort of fuel/air swirling thingie, so you can take advantage of that with this. Nice...
Old Jul 12, 2002
avenger's Avatar
avenger is an unknown quantity at this point
thats sweet
Old Jul 12, 2002
MisterTinkerTrain's Avatar
Proud Protaganistic Propagandist
MisterTinkerTrain should not be trustedMisterTinkerTrain should not be trustedMisterTinkerTrain should not be trustedMisterTinkerTrain should not be trustedMisterTinkerTrain should not be trusted
Sweet. I've been waiting for this.
Old Jul 12, 2002
sspem2's Avatar
em2
that would b nice on our civics. r u going to try it grey.
Old Jul 12, 2002
VNlilMAN's Avatar
The Standard One
how exactly do you hook that up? cause ya i know you drill a hole in the intake most of the time.
Old Jul 12, 2002
Grey's Avatar
DIY King
Yeah, I know. TF&TF comes to mind. [IMG]i/expressions/laugh2.gif[/IMG]
I'm not going to do this myself anytime soon. I'm going for a turbo anyway.
Although N2O and turbo's are possible.
You basically need these and a regular nitrous kit. Then instead of drilling a hole in the intake for the nitrous nozzle, you unscrew your stock injectors. Screw these little adapters in. Then you screw your stock injectors back in and you hook up the nitrous and fuel lines to the nitrous and fuel ports on these units. The only thing that you'll need is a 4 way branch of the fuel and the nitrous since you'll want to split those for each cylinder.
Old Jul 12, 2002
VNlilMAN's Avatar
The Standard One
where exactly is the stock injectors? sounds like a harder diy then hooking it up to the intake... but then i read about someone sprayin in first gear and their intake manifold blowing so i guess this way is safer....
Old Jul 12, 2002
GanariGuY's Avatar
GanariGuY is an unknown quantity at this point
1000 BUCKS for nitrous........... damn that's like 1200 bucks after installation and shiizt........
I rather go with the old way......... and save my money........ the old way is safe unless ur a bonehead
and spray on first gear.......... retards
Old Jul 12, 2002
megacivicfan's Avatar
megacivicfan is an unknown quantity at this point
I noticed that setup and thought it was a great idea, but I think Holley needs to be a bit more reasonable on the pricing. I've heard the stories on exploding intake manifolds, and remember reading various nitrous system manufacturer's notes on installation. Every one I saw said "NOT" to use platinum plugs, and seeing that all 7th gen civics come out of the factory with platinum plugs, think this might be a factor in the exploding manifolds?
Old Jul 12, 2002
VNlilMAN's Avatar
The Standard One
on autos and when your using WOT and floor it from the start, would that cause it to spray in 1st gear?
Old Jul 12, 2002
Dustman380's Avatar
Dustman380 is an unknown quantity at this point
can I borrow 1000 bucks??
Old Jul 12, 2002
I believe most systems use either a microswitch that is usually set by the installer to activate the nitrous at WOT, or use the throttle position sensor to do the same. Regardless of how it activates, the nitrous system doesn't look at what gear you're in. So if your system is armed and the switch is hit, 1st gear or not, you will spray.
h4ldol
Apr 24, 2017 08:16 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
ttamrekab
Sep 28, 2015 01:22 AM
