DIY: Springs *no pics though*
Old Jun 1, 2002
VNlilMAN's Avatar
The Standard One
more detailed DIY springs *sorry no pics tho*
since the other diys weren't very clear i decided to write this up... sorry i dont have pics tho, maybe someone could take pics when they do the install. but ya i suggest you look at the pictured diys(for coilovers) found under the "DIY" section up at the top for further reference.
imma try to explain this the best i can...
front:
1) jack up BOTH sides of the car(or you'll have problems getting the strut back in) and make sure its on the car chassis not any panels. and remove the wheel.
2) open the hood and loosen(dont take it all the way out) the bolt that is in between those 3 bolts that hold the strut(if you do this it'll be easier to take the strut apart, and i dont think you need an allen key either)
3) remove tie rod(doing this first makes it a little easier cause it keeps the strut in place). remove the cotter pin and the nut. you can remove the tie rod byb renting a tie rod seperator(autozone has it). just hammer it in and after you think its in far enough, lean on the tie rod seperator and it should pop off. oh and dont worry about ripping the boot, its only like a dollar or so
4) remove the brake line from the bottom of the strut
5) remove those two bolts that connect the bottom of the strut to the brake rotor. when you do remove the two bolts, the whole rotor is going to fall. i put my spare tire under it to sort of catch it. someone said to put the jack under it but i dont think it would hold it... i'm not sure how it would happen but for one person, the axle popped out of the cv joint or something and he had to open it up and put everything back together. so ya i guess becareful and try not to let the whole thing just drop or let it hang. so either use the tire or the jack, better safe then sorry...
6) remove the 3 bolt that are located under the hood.(remember to catch the falling strut)
7) now that you have the strut out, get a straight edge and mark the bottom and top of the strut. this is so that when you put everything back together, it'll all be aligned right. oh and i understand that the very top part of the strut moves around... just line up the arrows and thats the way it goes... and those 3 bolts only go in one way so....
8) compress the spring with the spring compresser(since your reading this, your probably new to this so i would highly recommend one). if your doing this by hand good luck its going to take awhile... you'll probably have to compress it till it wont compress anymore...
9) once the spring is able to move around, its safe to remove the bolt at the top. if you loosened it like i said earlier, it shouldn't be too hard. if you didnt, your going to need an allen key and some strength...
10) remove the whole top part(i removed it in one piece rather then removing it peice by peice)... the top part does have ***** in it, but if you remove it as one piece then you wont even see them.
11) remove the spring and put in the new one. i had to compress mine(neuspeed sport) to get it in...
12) put the top part back on(remember to line up the lines you made from step #7). and make sure the springs sitting on the top and bottom part correctly...
13) decompress the spring(if you had to that is) and remember to keep everything aligned as you decompress it cause it might move around..
14) put the top bolt back on. it doesnt have to be in all the way, just enough so that it safely stays in...
15) put the strut back on the car starting with those 3 bolts under the hood
16) put in the 2 bolts on the bottom of the strut starting with the lower one(i found it easier this way...)
17) attach the brake line back to the strut
18) put the tie rod back in. put in the bolt and cotter pin in as well...
that should be it... just do the same with the other side
back:
1) jack up the car.
2) there are 3 bolts connecting the strut to the car....remove the top two bolts(these are found right behind the seats in the trunk). you have to remove the 'carpet' from the sides to get to them. you could try loosening up the middle bolt for this too. not sure if it'll work cause i forgot to try.
2) not for the last bolt, get under the car and remove the bottom nut. if you cant find it, just look where the strut connects to at the bottom and you should find it. its the same size as the lugnuts and it might take come strength to get it out. just take off the nut and tap the bolt out afterwards. the strut still might be stuck inside the place it sits in so you might have to manuever it out.
3) now you should have the strut in your hands... as you did with the front, mark the top and bottom of the shock to algin it right when you put it all back together(i learned the hard way)
4) now you have the shock in your hands... your going to need a good spring compresser for this... i had trouble because mine was bulky and it got in the way of the plastic thing(that covers the shock from dirt). compress the springs(it takes a lil longer then the front)
5) use an allen key and wrench to take off the top bolt
6) take out the spring and put in the new one. put the top bolt back on. for this i had a real tough time again because of the spring compresser. not only did i have to compress the spring to get them in, the compresser got stuck when i decompress the springs. oh remember to keep the bottom and top part aligned with the marks you made.
7) put the shock back in starting with the bottom bolt. if it doesn't fit right, you didn't align it right... if its just a lil off, hammer it in cause its hard to get it perfect.
8) tighten the top two bolts
if i remember anything else i'll post it. hopefully this will help someone. i know i could have used this. i wasted like 10 hours because the diy wasn't detailed enough....
Old Jun 4, 2002
VNlilMAN's Avatar
The Standard One
thanks. if you do attempt it, make sure you have a good spring compresser. that'll make a big difference from making an hour diy and a 12 hour diy.
i know that few people say they didn't use a spring compresser, but if your reading this, chances are it would be very difficult/dangerous to do it without one.
Old Jun 6, 2002
Perfectcivic's Avatar
Perfectcivic is an unknown quantity at this point
I'll agree with that the backs you dont really really need a compressor but its nice but the fronts you definately do mine wasnt on as good as it shouldve been and the bolt shot off and i had to look for like 10 mins for it.
Old Jun 9, 2002
Numinous001's Avatar
Numinous001 is an unknown quantity at this point
Would a spring compressor be available for rent at an Autozone type place, or is it something that isnt too costly where I could consider buying one?
-Numinous
Old Jun 9, 2002
VNlilMAN's Avatar
The Standard One
autozone lets you borrow it for free(give them a $50 or sum dollar deposit and you get it back when you return it) but it sucks. i got mine from them and it was a pain the butt to use. n yes i'll admit, i gave up with those.
Old Jun 14, 2002
dragoon's Avatar
spring compressor definitely helps. with 2 other people, it took about 20 minutes per spring.
Old Jun 16, 2002
Machina's Avatar
Machina is an unknown quantity at this point
my friends and I lowered all our 3 cars...after wasting time with the spring compressor we rented from Canadian Tire, let me just say that it is not necessary...sorry to those who wanna argue but with 2 people holding down on the top, when the nut came off, we slowly let up and nothing went shooting anywhere...so if you have some help, which obviously you will if you're going to DIY, don't worry about the spring compressor...
Old Jun 26, 2002
Mbow's Avatar
Thanks for the DIY! I printed and used it this past sunday to install my springs. I ended up not using a compressor and it went much quicker. A little more info on removing and reinstalling the rear strut would have been more helpful but I figured it out. The rear would be much easier with two people. Anyhow, thanks a lot.
Old Jun 29, 2002
BlueFlame's Avatar
BlueFlame is an unknown quantity at this point
Spring Compressor costs about $50 or so, or you can rent one - free in a big city - or if you live in smalltown, USA like I do, it's about $5-$10 a day. I think I'll try and tackle it tomorrow. Any ideas how hard it would be to do by yourself? 'Cause everyone I know thinks I'm a moron to do it myself and not have a shop do it. Hmm .. $250 for the shop, $6 (spring compressor rental) for the DIY. Right - I'M the moron ..
Anyways, back to the point - just yourself, about how hard would it be? Thanks ..
Cheers! [IMG]i/expressions/beer_yum.gif[/IMG]
Old Jul 2, 2002
Royando's Avatar
Royando is an unknown quantity at this point
hey hows it going? i was reading n stuff.and i jus ordered some sport neuspeed and ill be getting them like in about 1 week and half cuz the guys that i ordered from dont have them in stock..its cool..so yeah i would appreciate if you send some DIY pics this way, i already printed out the instructions for it..so im sure that Pix will help.... email: Latinojw@hotmail.com
thank you[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jul 2, 2002
maverickja17's Avatar
maverickja17 is an unknown quantity at this point
I had a problem with getting the pics. I have pics for the first half of the install but then a thunderstorm blew in on us so we had to finish as quickly as possible. I can tell you that you will need to get the tie bar separator and the compressor to make the job go more smoothly. We didn't have to compress the Gold-lines at all to get them back in. Don't forget to shave bumper stops if it is recommended, we did on the back and had to redo the whole thing.
Old Jul 16, 2002
HeRbaLuS's Avatar
HeRbaLuS is an unknown quantity at this point
is dropping a 7th gen anymore different that dropping a 6th GEN??
Old Jul 17, 2002
snowman2002's Avatar
snowman2002 is an unknown quantity at this point
"is dropping a 7th gen anymore different that dropping a 6th GEN??"
A little. Actually the 6th generation maybe a little easier. One less bolt on the top of the struts and you don't have to worry about the brakeline.
Old Jul 17, 2002
VNlilMAN's Avatar
The Standard One
or the tie rod end which was a pain in the butt for most people including the first shop i took it too
Old Jul 18, 2002
civicdeveloper's Avatar
civicdeveloper is an unknown quantity at this point
I just banged the s out of the metal steering hub that the tie rod goes into with a hammer. Tie rod end came right out. Didn't even have to use a separator.
Old Jul 20, 2002
Machina's Avatar
Quote
[hr]Originally posted by: civicdeveloper
I just banged the s out of the metal steering hub that the tie rod goes into with a hammer. Tie rod end came right out. Didn't even have to use a separator.[hr]
yep, spray some WD40 on it and hit it good...pops right out...found that out after we fugged up the thread from hitting it from the bottom...don't do that...haha...had to by a tap and re-thread it...whew were we ever sh!ttin' are pants when that happened....everything's fine now...
Old Jul 25, 2002
PicCoLoboi02's Avatar
PicCoLoboi02 is on a distinguished road
Hey...what's da best place to rent a spring compressor? I want to lower my car with some Tanabe Super Down Precedo springs without getting ripped off by car shops.
2002 Honda Civic Ex 5spd Sedan
Old Jul 25, 2002
VNlilMAN's Avatar
The Standard One
i know autozone and pep boys rent out spring compressers but they arent that easy to use... only thing good about it is its free to rent it. all you need is a deposit.
Old Jul 27, 2002
thxs a lot...i'm gonna install em soon with the help of a couple of friends. The drop should b around 2 inches
2002 Civic Ex Sedan 5spd
Old Jul 30, 2002
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
I'm going to be installing some Goldlines next week. Anybody thats installed thier own springs...could you list all the tools involved in the install? And what is a good jack to get for this?
Old Aug 9, 2002
1955's Avatar
hey VnlilMAN what a great help u gave us newbies to this wonderful world of honda civic,,i do have to say your help was clearly written to the simplest way to undersatnd ( i is a college student ) LOL but anyway,, you dont have to loosen the top strut bolt untill the strut is on a vice ( just put the top part of the strut sideway on a vice), a tire to hold the caliper seems to be the ideal cause nothin else worked for me..becarefull how the caliper turning once its hanging loose cause it can missalign the CV joint and it wont go back to the bottom of the strut no matter what you do..it took me(myself) a good 12 hrs for the job but the reward is fabulous,my coupe feels rock solid at 115mph (in a safe straight hwy) ,,it also help on braking by eliminating nose dive..thanx again for the help,,God bless U
Old Aug 9, 2002
VNlilMAN's Avatar
The Standard One
glad it helped... n ya there are many ghetto ways to get the spring out... i've heard of people letting it shoot into a bucket, covered it in a towel and put a tire at the end, step on the springs with your feet, etc... i just mentioned the safest way and thats using a spring compresser. and about the cv joint, i was afraid this was going to happen to me, it happened to someone here, he had to open up his cv joint, pack it with grease, buy some new bands to tie it closed. it just didn't sound like something i was capable of so yes please be careful and dont let that happen to you(you as in the person doing the install).
Old Aug 10, 2002
tekgnosis's Avatar
Ask me about your mom.
Ok...quick question.
When trying to remove the rear strut in a sedan...where are the bolts?? [IMG]i/expressions/face-icon-small-sad.gif[/IMG]
I did the front last night, with little effort, thanks to your DIY!
hrm...
I've looked under the carpet stuff in the trunk, but there's no bolts there [IMG]i/expressions/face-icon-small-sad.gif[/IMG] Is it behind that little sliver of a seat? I've folded down the seats, but there's still a bit left on the sides...anybody?
help...
Old Aug 11, 2002
tekgnosis's Avatar
ok, scratch my last question. I did the install, and thanks to the DIY, it was pretty easy!
it was hard to get at the rear strut, but I eventually figured out what you had to do.
I'll post some pics here later, in case anyone with a sedan is as retarded as me.
great DIY!
Old Aug 13, 2002
nytejade's Avatar
nytejade is an unknown quantity at this point
Ok a couple of quick questions...
Could you list the tools and measurements of the tools needed?
How big is the allen key? I don't own any allen keys at the moment ( they all got lost ) so I need to know which size to buy.
I currently have Neuspeed Sport Lowering Springs (4 door) and Konis installed.
I'm getting the 2 door springs for the rear in on monday. I'm going to put them in myself and i'm wondering if I'm going to have to align it after putting in those springs. It is going to drop a little bit, but not much. I'm assuming I will have to align it.
And about putting in the springs, do they have to go in any special way? ( imagine rotating the spring on the perch )
Also, I've been told the Konis have an adjustable rear perch. How would I adjust that?
I'm sure these questions are all easily answerable once dismantling the rear struts, but it never hurts to ask.
Thanks for the help. I will take pictures, but I'm only doing the rear.
Old Aug 13, 2002
VNlilMAN's Avatar
The Standard One
allen key, i'll check it later if i'm not lazy...
spring.. you'll see a groove on the bottom perch, thats where the end of the spring should be...
koni... i think you had to buy the adjustable perch one(if they even make one that is)
alignment... its alway recommended but i never did it... but hey all you need is a 2 wheel and not 4 wheel this time so...
Old Aug 14, 2002
nytejade's Avatar
You haven't gotten an alignment since you lowered your car? Or were you in the same situation I was in with the rear springs?
Thanks for your help, it's much appreciated. I'll have those pics up sometime next week.
Old Aug 14, 2002
VNlilMAN's Avatar
The Standard One
never got my car aligned after i lowered my car... my car was going straight and i had stock wheels anyways so i didn't care.. now i have 18s so maybe its a good idea to get it done..
Old Aug 14, 2002
nytejade's Avatar
Your car WILL go straight if you need camber adjustments. The only time it won't go straight is when you need TOE adjustments. When you lower your car usually only the camber is effected, not the TOE. You might want to get that done. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Aug 26, 2002
nytejade's Avatar
I forgot to take pics. : ( It was easy enough. I have Konis ( that i didn't install myself ) so when I was removing them and trying to get the spring off them I couldn't find the part for the Allen Key that you mentioned. That's the only part I got stuck on. There was no allen screw with the Konis.
