Retail Sales - site vendor annoucements Place for Vendors to post their specials and new stuff coming out or just advertise prices. These Vendors have been approved for posting in this section. Don't see anything new? PM them!
Top 6 Air Parking Heaters: Warm Your Vehicle Whole Winter
Old Dec 29, 2021
Maxpeedingrods's Avatar
Former Sponsor
Maxpeedingrods is an unknown quantity at this point
Do you want to travel across the world in your campervan or motorhome during the winter? Then you should definitely install a diesel air parking heater so that you don’t have to wait in the cold at your destination.
On the market, there are a few distinct types of air parking heaters. We are now hereby introducing you to the diesel air parking heater. Diesel air parking heaters save storage space, payload. Diesel is available all over the world and can be pumped straight out of the tank. This is a significant advantage because you don’t need any extra space for the fuel. You can, of course, always see how much diesel you have left on your fuel gauge. The consumption is just about 0.5 l per hour and 6 amps of electricity. In addition, the auxiliary heater weighs only around 3 kg, depending on the model.
air parking heater
Functionality
After the fuel, in our case diesel, is pumped out of the tank, it is then combined with air and ignited in a combustion chamber on the glow plug. The heat generated can then be released directly in the heat exchanger to the air inside the campervan. The power consumption is obviously the largest when the auxiliary heater is turned on. When the air-gas mixture reaches the proper temperature, it can self-ignite, eliminating the need for a glow plug.
Self-assembly
You should carefully study the operating instructions before deciding to install a diesel air parking heater in your van yourself. In some cases, these should be retrofitted by a specialist workshop. If you take the whole thing into your own hands despite this, you may lose the guarantee. However, if you are handy with tools, you can install the air parking heater on your own without any problems. A lifting platform can be an advantage here but is not necessarily required. Otherwise, of course, you can always seek assistance from a car workshop.
Suitable place
Of course, before you begin the installation, you must consider where you want your air parking heater to be installed. Where should the heated air be blown? In the ideal scenario, the entire interior should be heated. However, this is not always the case. There is the option of installing additional air vents to blow warm air into all corners. Also, make sure that the suction side of your heater can suck in air unhindered and that there are no parts in the vicinity that are prone to heat. If you do not have enough room in the van itself, attaching the diesel heater under the vehicle floor is also an option. But the heater should be protected somehow, such as with some suitable stainless steel boxes.
Our recommendations
We would like to recommend MaXpeedingRods best top 6 air parking heaters for your campervan. The diesel air parking heaters from MaXpeedingRods are great for vans and other sorts of vehicles.
1. 1KW-5KW Adjustable Diesel Air Heater with Digital Switch(SKU:AH-DS
  • Power: 1KW-5KW Adjustable
  • Heater Power: 5000W
  • Rated Voltage: 12V ​
  • Switch type: Digital Switch
  • Fuel: diesel
  • Fuel Tank: 10L
  • Fuel Consumption(L/h): 0.14-0.64
Buy Now
2. 5KW-8KW Adjustable Diesel Air Heater with Digital Switch(SKU:AH-DS-8KW)
  • Fuel Gasoline: Diesel
  • Power: 5KW-8KW Adjustable
  • Fuel Tank: 10L
Buy Now
3. 2KW-5KW Adjustable Diesel Air Heater with LCD Switch(SKU:AH-LCD-Z2)
  • Power: 2KW-5KW Adjustable
  • Heater Power: 1KW-5KW Adjustable
  • Switch type: LCD switch
  • Fuel: diesel
  • Fuel Tank: 10L
Buy Now
4. 1KW-5KW diesel air heater with LCD switch(SKU:AH-5000-1-V4)
  • Fuel Tank: 5L
  • Switch type: LCD Switch
  • Fuel Consumption(L/h): 0.14-0.64L/h
Buy Now
5. 1KW-8KW Air diesel Heater with LCD switch(SKU: AH-MN1HR-8)
  • Power: 1KW-8KW
  • Fuel Tank: 5L
  • Switch type: Know Switch
Buy Now
6. 12V 8KW Diesel Air Heater All In One LCD Display for Bus Car Truck Motorhomes(AH-8000-1)
Rated Voltage: 12V
Power: 1KW-8KW
Fuel Tank: 5L
revautousa
37
Aug 25, 2006 03:07 PM
jturbolx
23
Feb 9, 2005 09:21 PM
dezod
Oct 2, 2004 11:27 AM
