does anybody know how to put in a hand clutch?
Old May 24, 2002
silver2k2civic's Avatar
silver2k2civic is an unknown quantity at this point
I just got my car about 4 months ago, and of course I bought a 5spd. There is only one little issue, I have one leg.
I was wondering if anybody has ever seen a hand operated clutch on the stick.
I think I can run another cable to the existing clutch cable and add a hydrolic motercycle brake lever to it. Right now I am driving using a cne on the clutch which works but it's too slow and I always have to let go of the steering wheel to shift.
If anyone haas any idea if this would work or has seen anything like this before I would reakky like a little feed-back.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old May 24, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Dunno man. Maybe some kind of lever (like a mountain bike brake lever) mounted on either the steering wheel (back side?) or on the stick itself. I don't know how much travel you need though... (I drive an auto).
Old May 24, 2002
I think I can use a motercycle brake lever because it already has a hydrolic cylinder and resevior on it.
I want to put it right on the stick. I think it would be pretty fast even if you didn't really need it. ( just cause your hand is faster than your foot right.)
I used to drive an auto to, but I'm a control freak. It took me way to much to make the damn thing shift when I wanted it to.
Thanks for the reply, Where u from?
Old May 24, 2002
avenger's Avatar
avenger is an unknown quantity at this point
i think you are officially the Hard Core MT Enthuiast!
Old May 24, 2002
I'm hardcore about a lot of things. Driving is deffinetly one of the top.
u drive a manual?
Old May 24, 2002
Does anybody else have any suggestions?
Old May 24, 2002
matt95401's Avatar
matt95401 is an unknown quantity at this point
there was a teacher at my high school who was in a wheelchair and he had some sorta set up like that...not sure how it worked exactly though....or maybe you could get one of those push button shifiting systems...those are probably so expensive though...[IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old May 24, 2002
I looked at those to.
They work but then the clutch is either engaged or not, there is no between (ie.starting smooth would tuff)
I think this method would work I just don't know anybody that has the expertise to put it into effect. I also don't know if the hydrolic from a bike would be strong enugh.
I think I'm gonna try this. Ijust wanted to see if anybody had tried anything like this or if anybody had any input.
I was thinking about having the clutch on the stick, and just how fast that would be for racing.
I just can't wait to get the damn thing working![IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old May 24, 2002
artychris's Avatar
artychris is an unknown quantity at this point
look in the Super Street (feb 2002)... the 5Zigen team made a clutchless transmission by integrating the clutch in the shift ****... you should probably e-mail them on the specs on how to's on that and get yourself hooked up.
Old May 24, 2002
SWEET!
Do you have any idea where I would find an e-mail address for any of these guys?
That sonds like they had the same kind of idea but they integrated it.
Thanx![IMG]i/expressions/beer_yum.gif[/IMG]
Old May 24, 2002
Russps's Avatar
Russps is an unknown quantity at this point
My grandpa had a friend who had problems with his legs and he had a lever to the right of the steering wheel that operated the gas and the brake (up to accelerate down to brake). It worked quite nicely, I was 14 when I saw it, so I never got to try it, but it worked. I assume something similar could be made for a clutch.
Old May 24, 2002
7GRev's Avatar
7GRev is an unknown quantity at this point
sorry i have no info for you, but you inspire me, if i only had one leg, i would be striving to find a way to still drive MT... i could never drive Auto, tell us how your search goes.
Old May 24, 2002
Thanks for the support,
I think my idea will work. I'll post some pics if I can figure it out.
The way I'm driving now is o.K. its just slow and a little dangerouse in fast corners. I use a cane sorta thing attatched to my clutch pedal. like I say it works fine but I want t go faster, so I need more control.
[IMG]\\serenity\my civic(back)[/IMG]
Old May 24, 2002
LikeWEEEEEEEEEE's Avatar
LikeWEEEEEEEEEE is an unknown quantity at this point
have a racing setup mounted on your steering wheel, so just hit the button and bam new gear.
Old May 24, 2002
iamboo's Avatar
Retired - SoCal FI Mod
i give you major props man...
Old May 24, 2002
<< have a racing setup mounted on your steering wheel, so just hit the button and bam new gear. >>
But he still has to operate the clutch and throttle at the same time, but that would be a good solution for someone with one arm.
Old May 26, 2002
2K1SilverHX's Avatar
2K1SilverHX is an unknown quantity at this point
I'll throw in my 2 cents.... Why not use your good leg for the clutch and have the gas relocated???
It would require a lot less pressure and is probably less expensive....
Easier??? Don't know
Good luck
Old May 27, 2002
THanks for the support guys. I really appreciate it.[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
I tought about relocating the gas but it just seemed like it would be wierd. I guess thats only because I have my right leg so it kinda feels natural to have it on the gas and break.
I do appreciate any new ideas though so please by all means keep em comin.
Thanx,
Old May 27, 2002
WhiteRabbit's Avatar
well, a motorcycle break lever certainly doesnt have the throw your clutch does, so youd need a lever to equalize the path lengths of each... o man would you have to squeeze that sucker ever so hard to put it in nutral.
good luck tho
Old May 27, 2002
mohawkboom's Avatar
Relocate the clutch pedal to where the gas pedal is. Reloacte the throttle to the shift ****..??
Cheers
Mohawk
Old May 27, 2002
FastProf's Avatar
FastProf is an unknown quantity at this point
Stick with the motorcycle lever idea, it has merit. Problem is the clutch needs a lot of weight to move it. My Kawasaki ZX7R has a hydralic clutch lever that might be better than a brake set up. If you can find the right engineer, you might just have to run an intermediate hydralic slave cylinder to actuate the existing cluch mechanism. Good luck[IMG]i/expressions/beer_yum.gif[/IMG][IMG]i/expressions/beer_yum.gif[/IMG]
Old May 28, 2002
FastProf,
That sounds like exactly what I'm tryin to do. I just thought that I would use a break because it already has a hydrolic in line.
I originally wanted to use a clutch lever in it but I din't know how to rig the hydrolics. I need to find somebody to talk to that has some real knowlage of hydrolics.
Does anybody either know enugh about hydrolics to give me a shove in the right direction, or know someone who does?
Thanx again HUGE guys.
[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
p.s. tomohawk thanks man, if I can't get this to work I think that will be what I try next. ( I just would have to teach my fiance to drive with the pedals switched)lol[IMG]i/expressions/laugh2.gif[/IMG]
jbander
Jun 4, 2015 05:56 PM
dinsum
May 28, 2015 09:30 PM
jackshepardjr
May 24, 2015 09:53 PM
Tarbris
Electrical
May 3, 2015 09:51 PM
bsmiley
Apr 27, 2015 01:27 PM
