General 1st - 5th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
D15Z1 Rebuild
Old Sep 4, 2019
Darktriumph's Avatar
Darktriumph is an unknown quantity at this point
D15Z1 Rebuild
I have been researching the rebuild of my 1992 VX's engine. There are a handful of kits out there and I was wondering if anyone had recommendations as to brands/retailers? I'm doing a factory spec resto on the car so I am not looking for any performance kits.
Thanks!
Old Sep 5, 2019
mac25's Avatar
Dr Krieger of Modification
Re: D15Z1 Rebuild
...if you're going to spend the time and money on a rebuild, I'd go OEM (if you can find parts). Buy once cry once.
Old Sep 5, 2019
Re: D15Z1 Rebuild
All for it & 100% agree. As you eluded to, finding the parts is the hard part. Honda isn't exactly supporting these cars any longer.
Old Sep 5, 2019
mac25's Avatar
Re: D15Z1 Rebuild
You can probably still get the headgasket/timing belt/waterpump/tensioner set from honda.
ARP makes some amazing head studs.
I'd leave the valves if they seal.
The valve seals, and, front/rear main crank seals can be any trusted generic automotive brand. Same with the basic seals (Intake, exhaust, vtec ect...)
The main things to research will be the main bearings/rod bearings ,and, the piston rings. Finding a good brand for this is key.
Old Sep 5, 2019
Re: D15Z1 Rebuild
Good info, thanks. It looks like hondapartsnow.com may have OEM bearings. I will check tomorrow.
seoul4korea
Mar 14, 2013 08:11 AM
fishdip
Feb 22, 2013 05:04 PM
waltdow
Mar 20, 2011 07:45 PM
heyitziak
Sep 20, 2005 10:59 AM
James00_33
Mar 25, 2003 01:15 AM
