HOW PUT THE BODY KIT BACK ON THE CAR , IT FELL OFF
WHATS UP , I NOTICED MY BODY KIT IS COMNG APART AND CAN SEE THE GLUE OR SOME KINDA OF DOUBLE SIDED TAPE, THE SIDE SKIRTS ARE SCREWD ON BOTH SIDES BUT THE MIDDLE SEEMS TO BE ATTACHED BY SOME STICKY STUFF WHICH IS NOW TEARING APART LEAVNG KIT KINDA LOOSE, HOW DO I PUT IT BACK ON? WHERE DO I GET THIS GLUE OR TAPE ?
Is it the OEM Honda kit? If so, I'd bring it to them. If you did it yourself, I'd take it off, get some good tape from a body shop and reinstall it. Look at HandAaccessories.com for installation instuctions.
caps lock button, on the left, turn it off!! it's so hard to read stuff when it's all caps, and you don't need to yell. as far as the body kit, why don't you just glue it back on? isn't it bolted in somewhere??
First you should remove your body kit, then clean the area with simple green or something. Next go to Home Depot and buy some 3M double sided tape that is water proof and put it on the kit. Then put the kit back on your car. Most kits tend to fall off because water weakens the tape, so the water proof double sided tape should do the trick.
Ok cool, its just pulling away from the body. When I read the title I was like WTF?. I could invision you cruising down the road and plop it falls off or something.
Sorry I dont know how to fix it though.
dragonsblood
Apr 27, 2015 12:28 PM
GaryFishell
Apr 24, 2015 06:49 PM
it solves everything!
