1990 Honda Civic Hatchback (JDM Integra Type R B18C Swap)
$6500 - Clean title and intended to build this for track purposes but ended up just sitting and looking pretty in my garage. The car was only driven less than 500 miles with the parts listed including the swapped JDM motor (about 40-50k miles according to HMotors). Only selling to buyers willing to pick up the car in the San Fernando Valley area (about 15 miles north of Hollywood). I have the full invoice for the parts listed. About $13k invested in the car so this is a great deal and I just need the money.
Newly painted (no dings or scratches)
EF B18 VTEC engine swap, including remove/install clutch kits and timing belts
RS Watanabe R-Type Wheels wrapped in brand new Federal Tires 205/50/15
Install Traction bar
Remove/install pedal assembly
Remove/install clutch master and sleeve, including bleed clutch system
Remove/install front control arm, and front and rear hub bearing and extended wheel stud
Remove/install coilover
Remove/install front and rear hub bearing, brake/rotors and brake line
Install back exhaust and testpipe
Install front/rear camber kits
Install battery relocation with cable and terminal
4 wheel alignment with camber arm (front and rear adjustable)
Used 92-95 Civic Pedal Assembly
Used engine bracket
Used T bracket
Used brake proportion valve
Crank seal
Camshaft seal
Tensioner
Act 8.8 lb flywheel
Act Clutchkit 4
Mishimoto radiator hose kit
Timing belt
Innovative Competition bar
Front mount bracket
Rywire OBD2 MIL Spec D & B series
Stell motor mount kit; cable to hydro
Moroso oil pan
Oil pan gasket
Shifter linkage
Walbro Install kits
Walbro 2SS pump
Sparco pedal
Sparco pedal (ordred for brother)
Cable to hydro conversion kits
Mishimoto aluminum fan shroud
Koyo radiator
NRG Short Hub 1
Momo steering wheel
Hood spacer
Clutch sleeve
(2) Rear hub bearing
(2) Front control arm
(3) Syncho gear oil
Invidia test pipe
Manifold gasket exhaust
(2) Front axle (left + right)
Front pad
Rear pad
Winmax FR pad
Winmax RR pad
Buddy Club Spec II exhaust
DC header
Front camber kits
Rear camber kits
Function & Form coilover
Crankshaft pully
Alternator belt
Acura integra ignition harness
Used engine bracket
Used T bracket
Crank seal
Camshaft seal
Tensioner
Act 8.8 lb flywheel
Act Clutchkit 4
Timing belt
Front mount bracket
Moroso oil pan
Oil pan gasket
Shifter linkage
Walbro Install kits
Walbro 2SS pump
Sparco pedal
Koyo radiator
NRG Short Hub 1
Momo steering wheel
Hood spacer
Clutch sleeve
(3) Syncho gear oil
Invidia test pipe
Front pad
Rear pad
Winmax FR pad
Winmax RR pad
DC header
Front camber kits
Rear camber kits
Crankshaft pully
Alternator belt
clubsoto
May 1, 2019 09:23 PM
hardliner
Jul 23, 2012 12:44 AM
money_matt7
Jul 30, 2010 06:31 PM
JoeB16
Jul 8, 2002 05:45 AM
