2005 Civic EX Best Offer
2005, 197,252 miles, original owners. All paperwork since new.
Needs head gasket, bank 2 O2 sensor, catalytic converter, head decked, new oil seals
@ ~176,XXX miles waterpump and timing belt replaced, also new rear shocks, driver side wheel bearing.
Has newer NAPA cooling fan, good tires, newer battery. HVAC Temp control module replaced around 160k miles
Has rear camber adjusters. Always used Castrol motor oil with K&N filter plus K&N air filter. Spark plugs were upgraded around 110K miles and are still good. Every other oil change starting at 80k miles I drained the 3 quarts of transmission fluid and refilled with factory brand fluid.
I used OEM parts from Majestic Honda including water pump, timing belt, rear shocks, brake pads and new rotors @ 165k miles
New head gasket and some other parts included.
3 keys 2 remotes all work/original
Bought new in CA. Currently clean Michigan title but is in OC SoCal.
Thank you,
Jason
Thank you,
Jason
Last edited by Meidilee; Apr 14, 2018 at 06:38 PM. Reason: I didn't think that the pics uploaded
hsjakame
Dec 13, 2008 05:37 PM
joewmorrissey
Dec 5, 2007 04:06 PM
Skydivincoastie
Jan 20, 2007 06:56 PM
ImPulse
Feb 21, 2005 11:12 AM
Xotic02kcivic
Feb 13, 2005 04:21 PM
