Spark plug leaking oil
Old Mar 8, 2018
SlowboyZ's Avatar
SlowboyZ is an unknown quantity at this point
What is causing my spark plugs to have oil? I was changing my spark plugs and I noticed that the spark plug has oil on 2/4 of them. I changed my spark plug tube seals last year as preventive maintenance So I don't understand how it happened. Only the 2nd spark plug to the left is leaking oil.
Old Mar 8, 2018
Re: Spark plug leaking oil
Plugs cannot leak oil. They don't have oil inside them, and there isn't supposed to be oil on either side of them.
Did you find the plugs swimming in oil from a valve cover gasket (tube seals) leak this time?
Were the plugs cleaned spotless from the leak the previous time, or replaced?
Were the coil boots cleaned or replaced?
I have found plugs with residue after running the engine for a long time with the plugs loose, some installer didn't get them tight enough to squash the gasket and then combustion gases seep past the threads....and usually when this is the case, the plug has a lot of resistance as you unscrew it because carbon builds up in the threads.....and the boot is also covered in soot or brown residue when there's been a lot of leakage, sometimes the plug is discolored from getting very hot as well
Really, if it's not the above situations, it's nothing to worry about.
A darkened ring found around the porcelain in the (exposed) space between the plug wire boot (or coil boot) and the steel is very common. It's caused by high voltage corona discharge, called a 'Corona stain'. It's very prevalent in engines with plugs deep in a semi-sealed tube
LINKY CLICK:
http://pmmonline.co.uk/technical/spa...-corona-stain/
Brandon04GT
Aug 27, 2019 12:25 AM
TS2008
May 4, 2016 11:45 PM
satown210
Mar 2, 2011 05:46 AM
gearbox
Jul 19, 2006 08:20 PM
AntiLoop
May 17, 2006 01:37 AM
