Crank but won'the start randomly
Old Apr 18, 2017
Steventmackay's Avatar
Steventmackay is an unknown quantity at this point
My son has a 2005 1.7 civic that sometimes cranks fine but won't fire. The funny thing is that when this happens the car will fire right up if push started. It will then be fine for a few days then it happens again. It has shut off a few times while driving when the clutch is pressed but always starts right up again. It has no stored codes. If anyone has come across this or has ideas I would be very happy to find the cure.....I'm getting tired of pushing. Thanks
Old Apr 18, 2017
Re: Crank but won'the start randomly
Hell IDK....
WHen it won't start, does the check engine light come on? It is supposed to come on for a bulb check-----and if it does not illuminate at all that's a good indication the PCM isn't getting powered up for some reason (main relay, and fuel pump relay can do the same intermittent failure and randomly not turn on the fuel pump)
Is the battery good and strong, fully charged?
Starter cranking speed is fast, and not slow or dragging?
check grounds?
battery/body/trans,
and radiator area to upper neck on front of engine (above thermostat), the braided cable
and the smaller pair of wires (on an eyelet right next to the braided cable) that provide grounding for the PCM and most of the engine systems.......
all need to be clean and shiny metal contact no corrosion, and tight?
Otherwise, you might try figuring out if it is missing spark or fuel when it won't start
Old Apr 19, 2017
mikey1's Avatar
if thats the case make sure your starter is actually turning the engine and not just making noise
Old Apr 19, 2017
Thanks for the replies guys, the problem is spark related, my son is working as an apprentice mechanic (although the shop isn't much help) and with a scanner he was able to see that there was no spark one time that it wouldn't start. Unfortunately the problem never stays long enough to trace. the battery is good and it always cranks fast. if he has no one to push he cranks...waits....cranks...waits until it goes, when it does go it fires right up. The check engine light does come on while cranking, the fuel pump can be heard and the starter is turning the motor. I'm going to get a wiring diagram and follow what I can as well as re-terminate all grounds.....I'll give an update, Thanks again.
Old Apr 19, 2017
Check CKP sensor terminals for evidence that liquid has entered and begun corrosion, and check for evidence of corrosion in the female terminal(s) of the harness connector.
Check female terminal tension (pin drag test), make sure they haven't become loose or broken
apprentice shop?
Old Apr 19, 2017
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Is this a case of bad electrical contacts within the ignition switch? I don't recall the 2005s being one of the affected years for the ignition switch issues.
Also it wouldn't be an immobilizer issue too since I thought that the fuel is cut off and not the spark?
Old Apr 19, 2017
mikey1's Avatar
but obviously the spark is fine when you push the car
