Crank seal oil leak replacement cost
Old Dec 5, 2016
SlowboyZ's Avatar
SlowboyZ is an unknown quantity at this point
I went to see my mechanic for a small oil leak i've been ignoring. He quoted me $320 to change the crank seal and timing belt. Since he's going to replace the timing belt, what other parts might need replacing ?
Old Dec 5, 2016
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Re: Crank seal oil leak replacement cost
That's a good price.
I'd consider replacing the water pump, tensioner, cam seal, 2 accessory belts, thermostat and coolant as well while in there. Then you would be good for another 100k miles.
Old Dec 5, 2016
SlowboyZ's Avatar
Is the crank seal in the tenioner? im ordering the Gates timing belt kit w/ water pump. I want to make sure I have all the parts for my mechanic.
Old Dec 5, 2016
Colin42's Avatar
no the crank seal is in behind the crank pulley
Old Dec 5, 2016
It may be the oil pump needs resealed instead of (or in addition to) the front shaft seals. Beware.
Without teardown and inspection, it's darn hard to tell.
Recent, this one had 180,000 miles on it and was leaking bad enough to soak the frame and blow oil all under the car:
Old Dec 10, 2016
dsm482's Avatar
dsm482 has a spectacular aura aboutdsm482 has a spectacular aura about
i did both the crank seal.. and oil pump. cam seal..
on mine it was the oil pump seal for sure.. there is specific gasket there that fails.
How do i know these.. I did the crank seal first.. then i still had oil leak , so i had do the job 3 times.. hey but labor is cheap .. its called my back)
