D2 Racing RS Coilovers D-HN-20 adjustments
Hi I have these set of coilovers for a honda civic 2001 and I wanna repair the rear shock absorber bushings. The previous bolt got stuck in there so it needed to be cut off.
I'm thinking the best way to get the old bushings out would be to use one of these pressed tools? See picture2
and probably an electric impact wrench like 330 ft per lbs torque minimum, would that be enough?
Also would this bushing would be fine to fit these rear coilovers? See picture3
One last thing, is it okay to say that the second rear bushing is fine even though the little ends slip offs easily , im thinking replacing it too. See picture4
Any suggestions on how to go about this process would be greatly appreciated.
Re: D2 Racing RS Coilovers D-HN-20 adjustments
That tool may work if it has the correct size adapters. Sockets also work. Shouldn't need an impact.
Not sure if those are the correct ones. I personally would order OEM online from Majestic. They are probably not much more for a way better product that you know will fit.
