intermittent no-starts
Old Sep 23, 2016
Yossi's Avatar
Yossi is an unknown quantity at this point
02 civic with 197k. The car will start and run fine for a week, then it will crank but not start. If i wait 60 seconds and try again, then it may or may not start.
I hear the fuel pump humming when I turn to position 2.
No CEL
all i have is the gray valet key - could this have anything to do with the immobilizer?
I had the charging system tested and battery/alternator test fine.
It happens even if the car has been running for 30 minutes and then off for 30
I will replace the plugs tomorrow, but wondering what else I can do before bringing it into the shop?
Old Sep 24, 2016
Wankenstein's Avatar
Re: intermittent no-starts
Could be a weak fuel pressure? If, you don't know when the fuel filter was last replaced then start by changing that. If, problem still persist it may be a weak or failing fuel pump that has intermittent proper/improper pressure.
Clean throttle body.
sdaidoji
Mar 22, 2016 11:43 PM
mechris
Mar 5, 2016 09:16 PM
Tbonczar
Feb 22, 2016 07:38 PM
repasscustoms
Feb 21, 2016 05:57 PM
robbclark1
Nov 28, 2001 12:14 PM
