Engine Code
Old Sep 10, 2016
GusBuz's Avatar
GusBuz is a jewel in the roughGusBuz is a jewel in the roughGusBuz is a jewel in the rough
Engine Code
Hello all I have an 04 civic ex that had a p0134 Code, so i went ahead and replaced the air fuel sensor with the correct denso replacement 234-9017 to my knowledge.
Well shortly after replacing the sensor I cleared the codes and whent for a drive, everything seemed fine car drove and felt great. But all was not good, after a while engine light came back and had p0171, the car also felt like it lacked some power at about 3000 rpm.
I cleared the code and left the car at home, it sat for a couple hours and cooled down. I test drove it again later and all felt fine. i pulled coolant temp, intake temp, intake pressure and short term fuel trim on my scan tool pids. As the car came up to temp i noticed fuel trim climbing up to 46 and the car started to feel like it felt when the light was on earlier for p0171. When i got out i smelled my tailpipe and it smelled as if it was running rich.
Did I just get a faulty air fuel sensor? I also recently replaced the fuel filter and strainer because i had a gas leak at the top of the pump assembly and the car ran fine until today when i replaced the sensor.
Edit (Ok after reading more posts on here by searching p0171 i found that someone had misfires because of dirty egr passages. Could this be my problem too? Maybe not enough to misfire but enough to run lean?...after going into closed loop and not using the default rich fuel maps??)
Haha i cant stop thinking about it! Drives me nuts not knowing exactly whats wrong. Also sorry for such a long post, its late and I should be asleep lol
Old Sep 11, 2016
mikey1's Avatar
Re: Engine Code
which sensor did you replace? there are 2 of them
do you have any exhaust leaks?
Old Sep 11, 2016
Re: Engine Code
Without knowing a lot more about the situation, I'd guess so.
Old Sep 11, 2016
GusBuz's Avatar
Re: Engine Code
The upstream sensor, and exhaust leaks i dont believe so but i will take a look to be sure
Old Sep 11, 2016
GusBuz's Avatar
Re: Engine Code
Drove it this morning, kept an eye on the scan tool pids and everything was fine even after getting up to operating temp. Fuel trim would be less or more depending on engine load and would not go over 20% at any moment.
I will be keeping an eye on it for a few days hopefully it stays this way.
dabatman99
Engine DIY
15
Jun 5, 2021 07:17 AM
sdaidoji
Mar 22, 2016 11:43 PM
malcolmgrey
Feb 28, 2016 09:21 PM
civicPesek
Nov 7, 2001 11:33 PM
