Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
spare tire ok ?
Old Apr 17, 2016
roger t's Avatar
roger t is an unknown quantity at this point
spare tire ok ?
I had a flat tire on the front of my 2015 Honda Civic EX. Replaced it with the "doughnut" & drove it to a tire shop (10 miles). When they saw the doughnut on the front, they had a fit ! NEVER install the doughnut on the front, because it will ruin the Xmission. I checked the owner's manual & it agrees with the tire shop, but it states only Honda Civic SI model, so is it ok installed on the front of the Honda Civic EX ?
Thanks,
Roger
Old Apr 17, 2016
mac25's Avatar
Dr Krieger of Modification
Re: spare tire ok ?
If it is still driving without issue, you shuld be fine.
My guess is that the Si model has an LSD and the two different tire demensions might cause stress on the transmission while it is locked. The base model may or may not have an LSD.
If no LSD then one tire is basically a trailing tire and shouldn't be damaged by tire size variation.
Also for safety having two proper tires up front for grip/braking/steering is safer.
Old Apr 17, 2016
Re: spare tire ok ?
It's fine on the front, your car does not have an LSD (limited slip differential)
Old Dec 30, 2016
franklin33x's Avatar
franklin33x is an unknown quantity at this point
Re: spare tire ok ?
I'm reminded of My Cousin Vinny
Old Dec 30, 2016
Re: spare tire ok ?
Have you ever fact checked that part of the movie?
yobie3
Dec 17, 2015 08:33 AM
stevelisan
Nov 11, 2015 04:52 PM
electrom
Nov 10, 2015 11:38 PM
AJ
Dec 4, 2001 09:08 PM
SleepyT
Nov 1, 2001 04:59 AM
