heya! please help 98 auto
Old Aug 11, 2015
hunda91's Avatar
hunda91 is an unknown quantity at this point
Exclamation heya! please help 98 auto
hey guys I'm having some problems with my 98 civic auto ,
I notice when the car is warmed up that when I'm at a stop and go to take off it just revs then finally goes .but once I'm going I'm fine it shifts into every gear .now that being said I found out if I manually put it in the lowest gear and take off it takes off fine .I dont know if when it warms up it get stuck in a higher gear and I have to manually shift it down or what ...what do you guys think it could be ?
Old Aug 11, 2015
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Re: heya! please help 98 auto
have you checked the fluid with the engine warmed up and turned off? Always check hondas with the engine NOT running.
Old Aug 11, 2015
hunda91's Avatar
I let the car get to operating temp then I check it with the car off or on ?
Old Aug 12, 2015
hunda91's Avatar
I check the codes with me scanner p0700 p0730 and I try looking for the transmission control module and I cant find it
Old Aug 12, 2015
mcnoople's Avatar
p0730 is considered a transmission "code of death." Honda has published info over the years that basically states that if you have p0730 (incorrect gear ratio) and the car has more than 20,000 miles that the trans needs replaced.
Old Aug 12, 2015
hunda91's Avatar
I mean it shift fine till it warms up then I I have to put it in 2 when I take off it shifts fine afterwards
solarpunk70
Apr 12, 2016 11:43 AM
Bruce2
Sep 27, 2015 08:45 PM
ttamrekab
Sep 25, 2015 04:41 PM
Skunkone
Sep 24, 2015 04:38 PM
