honda civic 2004 steering wheel noise
Old May 9, 2015
anddrrey's Avatar
anddrrey is an unknown quantity at this point
hi,i have honda civic 2004 with electric power steering.
the noise occurs after about a 20 minutes ride and only by pressing on brake or gas pedal....in addition, when i press the gas peda on high speed, the steering wheel became very stiff. please help....there is a link whith the problem:
Old May 9, 2015
Re: honda civic 2004 steering wheel noise
Check near the pedals where the steering shaft passes through the firewall or floor. Is the plastic shield in the correct place? Nothing rubbing the steering shaft or column?
If you turn the engine off is the noise still present?
Is the noise loudest in the engine compartment or in the cabin?
Use a length of tubing as a stethoscope to help locate the source area of the noise...
Old May 10, 2015
anddrrey's Avatar
the biggest problem that there is no noise if i stand on a place.....i need to reach approaximetly 50 km/h and more to hear the noise....
the noise sounds like its in the cabin...
the strangest thing is why the noise comes only when i press on the gas or the brake and simultanously the steering wheel become stiff...if i dont press a thing, there is no noise and the steering smooth.....
Old May 10, 2015
If the car has electric assist steering, is the warning light on? Any fault codes?
Old May 11, 2015
anddrrey's Avatar
its electric but there is no warning light....i dont sure but i heard that electric power steering turning off in a high speed(up to 50 kmh)....i think its true because in the city at low speeds the steering very smooth
bsmiley
Apr 27, 2015 01:27 PM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
jessicakaybby
Apr 20, 2015 12:11 PM
chgofirefighter
Apr 18, 2015 08:08 PM
