civic 2001 issue with the blower fan
Old Mar 29, 2015
ftareen's Avatar
ftareen is an unknown quantity at this point
I have a civic 2001 and facing a strange issue with the blower fan
- For the last few month, sometimes when I switch on the blower fan it does not work/start right away
- I tried changing speeds and all that but it will still not work, then all of sudden it will start
- I read some forums and people suggested that I should take out the in cabin filters and try rotating the fan and see if it needs a kick start. I did that but that did not help.
- Previously this would happen once in a few months but now its happening once a day.
- I am suspecting its not blower motor, because the fan does start working after sometime.
- Is it motor resistor going bad?
Any suggestions?
Old Mar 29, 2015
Re: 2001 civic temperature issues....
When it won't run on its own--- leave it turned on and go to the passengers side of the dash: Smack the bottom of the fan motor with your hand. If it then begins to run, the fan motor is bad.
EDIT: Moved to a new thread
Old Mar 29, 2015
ftareen's Avatar
Re: civic 2001 issue with the blower fan
@ezone: Tried that. Even remove the filters and tried kick starting the fan (while the switch was in on position) by rotating the fan manually. Did not work
Old Mar 29, 2015
You rotated it by hand to no avail, but did you hit it? Hard?
If you can't jar it into running.......Next step for me would be to test for both power and ground at the fan motor connector, determine if one or the other is missing.
Then maybe if that answer leads me in a direction, grab wire diagram and proceed from that point.
bsmiley
Apr 27, 2015 01:27 PM
TheCrimsonKing
Engine start problems
Apr 25, 2015 09:40 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
prowl
Apr 18, 2015 07:50 PM
liljoe
Nov 4, 2001 01:27 PM
